 loner said:
It wasn\'t actually punched in... a WOF mechanic a few months ago said the bearing was starting to get a bit loose, so he tightened the hub nut up, to get rid of the
movement... and he didn\'t re punched it...
And now you are trying to remove it to fix the buggered wheel bearing ? pretty much these are non adjustable if they get play they are on the way out.
all I can suggest is take it to a tire shop, get them to rattle it off then re tighten to some extent to get you home, I would not drive far is all.
 We are borg']
I\'m not actually sure if the bearing is screwed... but the CV is very noisy with certain steering angles... and I\'ve got some weird ABS stuff happening from that wheel at times... which I\'m confused about.
I know... it\'s so tight that when I put the end of the breaker bar on an axle stand, and drop the car... the shock compresses and it takes almost
the whole weight of that corner of the car. I\'ll try and find a really long length of pipe today.
2 meters of scaffolding pole cracked it with ease... and the CV is going to slide out nicely as well :) Just need to figure out what CV to get.
Anyone used supercheap, repco or BNT CVs... or should I use genuine only? This is just my daily hack Legacy Wagon.
Started on project intercooler sprayer. Failed due to it seems that my rear window motor doesnt work, has 12v going ot it but no water comes out the pipes/nozzle. Works fine when i plug it into the front window motor. Need to now purchase another motor/bottle and mount it in the boot properly. Total cost so far is 8$. lack of drill meant i cant actually mount the nozzles yet.
looking at that, you\'ll slice through your hosing when you close the bonnet... the edge of the stainless is bloody sharp
may also be cutting off water flow because of pinched hose
Finally replaced my cracked rear centre garnish. Only took a year and a half of being annoyed every time i looked at the rear to finally do something about it.
Spent the last week polishing it up a bit each night and looks the tits now that its on.
Finished fitting the replacement Secondary. While the TMIC was off I re-routed my Block Breather into the new Catch Can. Both Breathers (Heads & Block) T\'d together, 12mm each to \'Can\' then a single 12mm back to intake. Finished the turbo install, and went for a drive.
After 10 minutes I started thinking the oil is taking a while to burn off. Popped the bonnet and discovered about 4 litres of oil "volcanoed" out my dipstick hole :\'( Apparently my old 215000km engine doesn\'t like not breathing well enough. ::)
What a mess....2 cans of degreaser and an oil change, it\'s almost back to normal. Block Breather straight back to its own inlet hole. ;D
