Dumb Question Thread!
Jambun
 ADIKT said:
Where can I buy tension springs?
Basically I want to use tension springs on the slip joints on my headers (did some research and people advise using springs on double slips)
Try a motorbike shop - they commonly use springs on their exhaust systems.
 Tony']
Thanks Tony, good idea
 newsuba said:
Where can I buy a Slimport to HDMI adaptor or Slimport > HDMI cable locally ?
;D
what comes with a slimport ?
EDIT ok so nexus devices
I have one here that has 4 ends, one HDMI to 3 different ports ( micro USB,normal USB and one other) I thought I got it off trademe but maybe it was of ebay
Edit 2
Yup got one from trademe
 Tony']
Yep use expeansion chamber to barrel springs of the good old 2 strokes!! 5 bux a pair from most decent dirt bike shops.
 marc']
I think you gave me springs for my last set marc? Cant quite remember
 We are borg']
;D
Edit 2
Cheers, looked on TM, nothing at the moment.
Computer shops were useless.
Damn multi-formats- Slimport, micro USB, MHL - all look the same but are incompatible.
Grrrrrr
 newsuba']
;D
Edit 2
Grrrrrr
I could post you mine to see if it works :) it was an hdmi adapter so may not do slimport
 loner said:
if the hub is wobbly as bother whrn the center nut is off... it means the bearing rooted as fuckery ... right?
Incredibly rooted, on my V7 the hub was still tight with the center nut off and the bearing on there was pretty shagged.
 boon']
same here the only reason I knew my mine was buggered was from the noise the wheel made when going round corners
Okay, more of a price based question; how much are BH fuel pump assemblies usually worth? Stupid plastic, anyway a while back when I was first getting my car going, the plastic nozzle for the (I think is the breather, maybe return of sorts third hose, with simple bulldog style hose clamp) on my fuel pump assembly broke, so we repaired it with knead it; which worked fine, although now the fuel is leaking out and around the knead it and anyway its dangerous, and I need a new one, does anyone know how much they cost? And if you can buy them with just the plastic, no pump or anything?
Cheers.
Sent from my SGH-I927
Would I be better off using 3mm or 4mm ID hose to replace my solenoid box/vacuum lines?
I understand that stock is 3.5mm, but would I be safe to use either of these? Would think using 3mm would be better than 4mm....
Also, recommendations to purchase from?
 Rosssub said:
I\'d use 4mm. Just make sure you save and re-use the Restrictor Pill in hose 2.
Edit: the last length I brought was 4mm Scarles off Trademe.
http://www.uklegacy.com/forums/index.php/topic/122143-what-size-vacuum-line-is-used-for-the-solenoid-box/
4mm it is then. Off to Redline performance to pick up ~10M at lunchtime.
Replacing line 10 & 23 with 4mm tonight, refurbing solenoid box tomorrow, all vacuum lines at another date.
 Timmah said:
Is 3.5mm the same diameter for normal vac/boosty hose? I wana replace my hose with silicone black so it\'s sexy
I think it\'s 3.8mm so 3.5 is probably perfect (4mm fine). Transfer all Pills into the new hose, double checking every hose for a Pill.
  • Guest locked this topic
