Dumb Question Thread!
Jambun
 jesus said:
Why doesnt my radiator fan work?
Why doesnt my DCCD work?
Why doesnt my air con work properly?
If someone could answer all 3 that would be great.
hello, this is tech support
have you tried your car key in the ignition? insert and twist to START
Bloody thing decided to die in 3 inches of muddy ooze at the boat ramp. It locks up perfectly fine all day long for 3 months on the street then the one day i could use some extra traction all i get is a flashing light.
 ADIKT']
[quote name='bnneie said:
Will a Prova ECU out of an Auto \'94 GT plug-and-play with my Manual GT? 4 plug?
/quote]Got a feeling it wont. Auto VS manual
My line of thought also. Thought it was worth asking incase someone has first hand experience/knowledge.
 Roo said:
I\'ve run an auto ecu in a manual car in the past with no problems. But may be different in your application
Usually it\'s if you go the other way it won\'t work (manual ecu in an auto)
Interesting.
Now I\'m wondering if it\'s worth buying only to possibly find out it won\'t work :-\
First world problems.
I\'m making great use of this thread aren\'t I ::)
What\'s the deal with seats? I\'ve read that quite a few are interchangable and will simply work on the existing rails between different models.
Basically, I\'d be keen to get some bucket seats out of a diff model Subi, just curious as to whether anybody has any first hand experience in working with the rails in my \'94 BG5 and what would/could possibly work on or with them?
Chur
Chur
You can buy my v4 sti ones when I get some v7 sti seats
 ADIKT']
Chur
/quote]You can buy my v4 sti ones when I get some v7 sti seats
If they\'re going to work with the existing rails in my car - I will gladly.
 bnneie']
Chur
pretty sure thy will
I haven\'t done the swap myself but I always thought there was a single pin on the ecu that was either grounded or open circuit, depending on if it was in a manual or an auto.
i.e.either cut the wire or add it in.
Could prove to be difficult to locate on a bg5 ecu though as the pinout\'s on the net may not show that auto/manual pin.
 Rosssub']
[quote name='paulngui said:
Someone got sunblock on the vinyl bits of my interior, what\'s the best way to go about removing it?
I\'d try warm soapy water first. Wouldn\'t leave it on for too long either, it could leave a permanent light patch?
Unfortunately it\'d been some time since it happened when it was pointed out to me. Tried warm soapy water with a lot of elbow grease but it\'s till there. Hopefully some car care product out there can do the trick.
  • Guest locked this topic
