would you need to launch the car at a track day, all track-days ive been to you leave from the pits and launching from the pits would get you kicked out? just a side note really :)
sorry, i might be assuming track day means round and round track, not go fast, stop, crawl back and get time slip :D
-smurff
  • Replies 58
  • Created
  • Last Reply
Top Posters In This Topic
'2nd gear' 6200rpm & side step.
or pick the safe option & put it 1st & start from 2000rpm & work your way up in 500rpm increments until your satisfied.
if you start to smell clutch buning you not side stepping it quick enough :P & best tried in your driveway too then it's not far to push it when it breaks
if you pick the first option -get it on video
-smurff
Some track days have standing starts. Some very low key ones with plenty of time give you standing starts. Then at the other end of the clubsport (typed in clubsub :) ) there is an advanced '6x6' track day where 6 of you do a standing start in gridded formation. They seed you based on the day's earlier times so there's not likely to be much passing. It's an adrenalin step up from dual track days.
And den... some track days are actually a sealed autocross creatively using most of a racetrack in unusual formations. They are standing starts.
I added up my launches and would probably do over 50-60 per year. If you carefully launch :o ::) ;D , clutch and gearbox last a very long time.
 al']
-smurff
/quote]Some track days have standing starts. Some very low key ones with plenty of time give you standing starts. Then at the other end of the clubsport (typed in clubsub :) ) there is an advanced '6x6' track day where 6 of you do a standing start in gridded formation. They seed you based on the day's earlier times so there's not likely to be much passing. It's an adrenalin step up from dual track days.
really, sounds interesting, i need to find some of these type of trackdays to photograph, all the ones ive been to are the clubsub style
-smurff
 Munkvy said:
Start launching at the limiter and then lower your launch revs each time until you find the tipping point between grip and spin. A bit of wheelspin is a good thing as it reduces the loading on your box/driveshafts and is much better than bogging as it keeps the revs up too.
agreed, wheelspin is required. all of my fastest 60ft times have been with a reasonable but not full amount of wheelspin. i imagine it helps keep the turbo in the power band
 smurff']
-smurff
-smurff
Road & Track sprints at Manfeild Paul..
Standing start, Three laps.
Dual cars in the morning and multi car in the afternoon..
Good fun!!!!
 madmike']
-smurff
-smurff
Good fun!!!!
and taupo duel sprints, same format.
first round 28th may (2 weeks away)
It will vary car to car. Mine was pulsing between 5-5500rpm then dropping the clutch. Got regular 1.8 60fts with that.
After antilag lowered the revs a bit but was getting 1.6s regularly. 1.2bar off the line was fun.
Only tried the handbrake method once and felt uncomfortable with it.
launch controll set at 5500 makes a nice getaway with just enough wheel spin and traction
thats for a v7 sti tho
tried a few rpms but settled on that after tests
this is a good launch for a stock looking v8
  • 2 months later...
haha same here just got a legacy tt last week first manual but i cant master why my car is so jerky when changing gears every other car which is lighter can almost drop the clutch and it doesnt jerk but this one goes slow as and it jerk or bogs when changin outa first onwards
its a TT.. dont bother
cereal, I can get 1st gear launches to slide the sunroof slider back on its own thou! (about 20 mm
mmmm BBQ clutch...
If you got a dyno of your car you should try and launch it just above your max torque. If you get wheel spin then ease up on the rpm until they stop spinning. If you bog down then raise the rpm until it doesnt.
I prefer to nearly engage the clutch then drop it, then full throttle! Although the shock is bad for the drivetrain its better than wasting a clutch.
Either way your not doing your car any favours by "launching". D:
I stand by my quote which is now Sams signature. Grow a pair and do it properly!
However, for a twin turbo, if you want a 4WD subbie that can be launched, sell the TT.
well this is my first turbo car and it just so happen to be a tt because i went for the theory more is better. lol didn know it turns out to be such a hard thing to do. we can sometimes do drag race on the straights on the track during our track day, so i through it might be good to learn how to get off the line fast. and i through launching it was the best way, but it turns out its actually very difficult to get off the line quick in a 4WD turbo car...
 whatchain']
If you're referring to the TT legacy's having more turbo's as being better...well... that sux for you really.
Theyre fast for a fraction of a second till VOD kicks in, i found that doing dual sprints vs a tt, he had me for a second till i hit boost (and i don't launch above 3500rpm) then he hit vod and i pulled past him, he was running 20psi and i was on 13psi and he would almost be even with me by turn 1 at taupo from a standing start.
lets just say he buys 2nd hand ones and has mechanical sympathy for the H6 of a teenager with his 1st conquest
