A couple of pic's of the coupe and engine update
  • Replies 68
Have a nice chrome moly one custom made to fit with that interccoler
as for the bracket to hold the l/h catch can - YES i need to sort that - its on my list :)
Will post exterior pics in the weekend
final tweaking done on the tune tonight :)
Now when cruising along at 3000rpm in 3rd, stand on the loud and the rears are lighting up in the wet with dccd wound off
Just a change of gear oils before dyno tomorrow
Will post results as soon as i'm back home
long story short
the innvoate AFR gauge has been reading incorrect for all the road tuning done --- arrr
Over 2.0 AFR's out ! so dyno run was at over 9.0 AFR
Anyway made 248 at the hubs @ 24psi, plenty more once tuning is sorted
kind of happy, but happy to know that the AFR reading wasn't reading the other way ie leaner
Time for ECU upgrade and more tuning :)
unsure if its the gauge or sensor or calibration issue
will look at it over the weekend, and go from there
will prob upgrade ECU to G4 to give more flexible tuning
 Ichi Ban said:
long story short
impressive i was 2kW off we were bidding on what you will be getting i said 250kw LOL
 funkytown said:
STill a pretty reasonable number rick :) eell done. look forward to seeing it when ur up nearer 11.0
Its OK'ish, I'm also are looking forward to 11's and seeing what that brings :)
 X']
[quote name='Ichi Ban said:
long story short
Should have taken the AC belt off and that would have prob nailed it on the head at 250
 Ichi Ban said:
long story short
innovate LC1s are pretty rubbish really... Check out the NGK AFX for a cheap wb02 sensor that is accurate and reliable.
also if you know your injector size it's a good idea when tuning to reference IDC against AFR with a sensible VE estimate to make sure your numbers are sensible, especially so if you use an LC1... you can pick up things like being 2 AFR out straight away
  • 3 weeks later...
 Eight dollar']
[quote name='Scoobydoo said:
You still have the mounts for the strut brace in place, wouldn't you remove them if you can't use the brace? Or is it only off while you were working on it?
nah it fits mate , just off while he plays, think he made a custom one
They are used for holding cable ties, left tower lol.
QRAF has the same i/c and would have had to get a custom made brace to fit as well.
quick update, engine is out and stripped now
a couple of issues found which have been stealing some Kw's
things like - an out of round bore (x2), a headgasket that was leaking
Most alarming tho was the cracked crankshaft ! and an extremley worn small end bush on one of the rods
Big ends and mains are like new, so proof the oiling system modifications work
New parts being machining or purchased atm, inc a replacement block, clutch upgrade, balancing, revised deck heights for the pistons too, now sitting 0.016' above the deck. Heads being refurbed and set up again
And lots of new goodies from Rocket Ind, Rally sport direct , Cometic, Aerosport, and Brian Crower motorsports are on the way
Coupe should be back on the road in 2-3 weeks - Cant wait :)
