Fuel choice for the EZ30d
Cam_Jones
 Share
In the market for an EZ30 Lancaster/outback although a lot of owners seem to use 91 regularly. My understanding was always that Subarus need 95 or 98 (especially turbo models). Is an EZ30 that's had 91 used in it regularly be a deciding factor as to whether I consider buying the car or not? Cheers and TIA.
40 minutes ago, BMCracer said:
Mine knocks a lot on 98 ( totally standard car with factory tune ), so there's no way I'd buy one that I knew had been run on 91.
Yours must be a one-off or have some wear. Otherwise all EZ30's would be prone to that and they've got a good rep as a reliable engine
They all do it, you just can't hear it. I only know it knocks because I have the BtSsm plugged in and displaying all the time, so I can see it happening. Before I got the BtSsm I would never have known.
I’d be worried about general maintenance of everything else tbh
I got a Bp legacy at 232,xxxk, ive just done 50,000k this year in mine, got it this time last year. Only issue I’ve had was the a/c, power steering belt pulley bearing destroying itself
great cars, should have got one sooner
New Zealanders seem to have a huge issue with sticking the right / proper fuel in their cars.
I've watched people stick 91 into their 335's, S4's, WRX's  (makes a small part of me die internally).
In all fairness, no car should be running 91 ever, and JDM cars especially since they don't even fuel that drops to such terrible quality even available over there.
At least if you owned one, you'd have your own piece of mind knowing you're sticking the right kind of fuel in it.
If it's tuned for 91 what's the harm? Example would be the new Highlanders, spec'd for 91, run great on it. Our boat motor (Suzuki) specifies 91.
Suppose the difference being whether if its a Japanese import not. Unsure about newer model JDM imports if companies started tuning them for 91? I'm guessing 'NZ New' and market equivalents come factory tuned for 91 to accommodate for the s****y fuel 😁
NZDM cars predominately come as AUS spec models and when indicated, are tuned to run adequately on 91. Even current gen NZ New Mazda 2.5 Turbo engines are spec'd to run 91...  😕
Interestingly, their latest SkyActiv X engine requires minimum 95 octane or higher for the 'homogenous' or compression ignition petrol engine...
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
 Share
  • Similar Content
    • By Aptenodytes
      Hi there,
      I live in Nelson, take a tandem trailer with a 6.2m aluminium hardtop boat (total about 2 tonnes) to Havelock perhaps 5 times / year (it's 80km of winding, hilly road). I swap cars with my brother and use his 3.6l Commodore VE for boat towing (we share a family bach and boat) as my 1995 Legacy 250T would not have been up to the job. However my Legacy got a death sentence at the WOF last week (RIP ) so I'm in the market for a replacement. It would make sense to get a car that can tow the boat.
      I would like to get a 4th Gen Outback 3.0R (2004 - 2007 or so) and have spent some time trying to work out if it would be up the task of towing 2 tonnes. I've found plenty of information in this forum (thanks!) and elsewhere on towing with 3.0 Outbacks, but nothing definitive.
      - Tow rating for this car would be 1800kg braked (750kg unbraked).
      - Some suggest an additional trans oil cooler would be needed (some suggest it would be difficult to fit).
      I've read a few lists of good towing vehicles on horse float / boating sites and nobody has mentioned any Subaru for towing, not even once. They usually mention the standard big SUVs and also Falcon/Commodore etc. My gutfeel is that 2 tonnes is a little too much for an Outback based on kerb weight etc and the transmission / drivetrain would be worked a bit harder than it should be.
      So what does everyone think? My guess is if I said Hilux / Commodore everyone would say "yes", if I said 2.5 Legacy everyone would say "no' but if I said 3.0 Outback it's probably in that slightly worrying ground in between.
    • By Hinkie
      Hi Subagurus
      Inspired by Super Guitar Guy  and Super Stereo Installer I thought I'd share some information in appreciation of the super time and work these guys and everyone else generously shares here, thank you.
      I've decided to do the double DIN and install one of the new Kenwood DNX9180DABS HU with Navi and add the dashcam. Currently collecting my bits, plans, work in progress. I figure if I can get all that kit running my Outback will be more capable than a new one, (no dashcam!) and a hell of a lot cheaper! Plan is to use the existing amp. I think they feed 80W (RMS?) per channel but that's not confirmed. Still knowing how they perform I am happy enough with the McIntosh amp and speakers.
      In the mean time I wanted to swap the Japanese banded PF-4062l head unit with an (ex NZ GT Legacy) PF-2551l for the standard NZ bands.  Thought must be too easy!
      Wrong!
      Swapping the units, which have the same plugs (not necessarily the same wires though!) proved to make both the McIntosh display and the upper Nav screen (Still in Japanese) just flash and will not work....  Quickly turn off....
      After much thought and studying most of the Internet and with a little help from Jeremy I figured that the 4062 will have, being a later unit, a lot of stuff that integrates with the Jap Nav gear, and that it all connects through the 20 pin J800 socket that has a heap of wires that I've not traced, but they connect to the Bus, what ever smarts are therein, no doubt the intermediate SWC smarts (not found how Subaru interface the control with the HU, but probably academic) and the Nav and who knows what else. The more common Subaru 20 pin plug J901 just has the power lights and antenna amp power - all essential to run the Head Unit.
      So....Legacy PF-2551l will run fine in a JDM Outback as an interim radio for me. Woot. (without steering wheel controls connected) when one simply does not plug in the back J800 plug - for anyone wanting to try that. Will keep me going for now.
      For the planned Double Din install I've bought a "junk" PF-4062l from Croooober for its sockets, especially the 20pin DIN wired female socket. My original thought was to use all the sockets as that would smooth the interconnection, now that expectation I've now pretty much shown to probably be wrong so arguably it was an expensive 20pin DIN, but then seems they're not otherwise available at any price.... Part of the cost! For anyone wanting to also do this conversion I figure a junked EF-1208l amp could also be used as a 20pin DIN socket part source for the HU end to run to the Mac amp being used in the car. That would have been cheaper for me, but committed now. There's currently a cheap one going to the first taker....
      I bought some RCA leads which I'll splice into the newly imported DIN plug lead at HU end which I figure will be robust enough. Also will need to feed the amp on (I assume) with the +12V "Power on" to turn the amp on. Plan to find the Original Subaru GPS existing device and swap it with the new Kenwood one. Seems no point installing the digital antenna on the windscreen as I think (open to correction) there is no digital audio around to connect to in New Zealand, especially the Wellington region. Yet to resolve issues anticipated. The McIntosh kitted 'rus feature 4 speakers in each front door. The Kenwood has some rel sophisticated frequency smarts for feeding different speakers different frequencies, particularly to protect tweeters. But they don't go so far as 4 different speakers per front channel with intermediate single feeding amp channels(!). I don't know but expect there is a crossover network in each front door (anyone know?) which'll do the frequency distribution just fine. So that leaves me with the expected question of what cut off frequency to feed the sub woofer, and whether I trim any base of the four door channels. It might all just work without fiddling with any EQ. Not yet figured out what to do with the Nav unit, expect the Backing CAM works and is appreciated, all be it at a liney resolution. Be nice to have a 720p front and rear cameras with the front one thru a replacement 720p screen mounted between the vents, and the higher defn rear cam thru the Kenwood. Not figured that bit out. Comments welcomed.
    40.4k
    570.3k
