Stock intercooler has to come out for the secondary air pump delete surgery so I'm pondering an upgrade to re install. The stock item in the GRB seems a bit weeny compared to even the STi IC in v7/8/9/10, anyone used, heard good/bad things about ZSS
https://justjap.com/products/zss-intercooler-upgrade-subaru-wrx-sti-grb-gvb-08-15
$400 Aus is much more palatable than $1500 plus for Process West/Mishimoto/Grimmspeed etc.
Edited by Bugle
duh
Link to post
What kind of power are you expecting to push? The factory ones do pretty well with the stock turbo and other bolt on upgrades.
Link to post
No idea, I have some budget so it new tyres (my tyre guy is recommending Falken FK510) coils and plugs, preempting some things that will need doing like cam belt, rocker cover gaskets and an all alloy radiator (the plastic side tanks always let go eventually on the OEM item)
A few odd things need sorting, 5th gear does not like to be rushed, and there is an intermittent dead spot around 3500 RPM, send the Bilstein's off to Auckland for a rebuild as they are stupidly hard so probably due some TLC.
A catch can or AOS, rip out the secondary air pump (have a Tactrix cable on the way), potentially a new top mount then send it off to the dyno for a tune
More about keeping it crisp and reliable than a big power number
Link to post
Things begin arriving, suspect some of the long weekend will be under the ramps
Edited by Bugle
image doh
Link to post
Nice. I assume you're familiar with the process for the Tactrix/openecu and deleting the codes?
Link to post
Yeah, nga
Never done it before, but I've read/watched a bunch of things, I have an IT background and it looks to me like a BIOS setting change/update (with the same perils granted). Few basic precautions, a safe copy of the factory map just in case, I have the codes to disable, doesnt seem that complicated
I'm more concerned about what else I'll have to remove/deal with/put back on to get it done, opinion seems to range from its easy to its a mare
Any/all advice appreciated
Link to post
  • Subscribed Member
Was pretty straight forward when we did it on my parents previous STI's, an 09 and 11.
Just download the ROM, remove those few codes, save, and reupload. Was a bit of a pain to get it to connect initially to download it, but got there eventually.
The physical delete was easy as we had the motor out, but even with it in it wouldn't have been too bad. Depends how far you want to go with it, as the plate on the driver's side head was a bit of a pain to get to behind the up pipe.
Link to post
From talking to some people who spend too much time around dyno bays, often the no-name stuff is no better than stock. s****y fin density in the cores, or s***house welding and poor fit/finish let them down badly.
It's not a cheap car - my 2c is if you're going to do it, save up the pennies and get a PW.
Link to post
I have an unused process west top mount kit spare.
It’s in the box but wrapped in plastic and has cardboard over the fins. Was going to be carryon for the flight back from Australia, but then had upgrade from work and kept the box as more luggage allowance.
Link to post
In a reversal of fortune Repco have low profile trolley jacks on sale for $59 at the moment, procurement completed.
I have axel stands already, progress resumes
Link to post
Damn it why can't I be content with repco supercheap stuff, my low profile Torin one was many many hundreds of dollars 🙄
Link to post
19 hours ago, Gripless said:
4x2 wood in front of ramps works too.
I would have had to go to the hardware store to get 100 x 50 anyway, and the ramps are pretty vintage, like 245's are wider than the ramps vintage
Link to post
Lol I have an alloy one and it’s still in box after many years.
pretty sure it’s still new in there.
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
