Moved My Amp From The Top Of My Sub Box and re mounted it on the back of it, now i can actually get under my boot tray to the spare wheel! yay discovered it was a 900 watt amp too so thats a bonus i thought it was just a weee small one
also got my new tyres hooked up look mean, (they even painted my brake calipers up by the looks of it haha) & discovered a clearance issue, will be calling mag and turbo in the morning
but more on that Here:http://www.clubsub.org.nz/forum/index.php/topic,24940.0.html
i havent done anything to my car but some assshole has tryed breaking into it went out a few mins ago and the drivers door lock has been fucked with whats left of the lock is inside the door somewere. on the up side they didnt actually get into the car
Oil
Oil Filter
Fuel Filter
Diff Oil
Air Filter
Brake rotors
Brake pads
Flushed/replaced brake lines
Flushed/replaced clutch fluid
Flushed/replaced coolant
Added some injector cleaner
FUCKING Spark Plugs!!!! Never again >:(
And thats all folks.
 bsod said:
Oil
Oil Filter
Fuel Filter
Diff Oil
Air Filter
Brake rotors
Brake pads
f***ING Spark Plugs!!!! Never again >:(
Now some upper cylinder cleaner :) But you've been busy!
 ONeill said:
removed the engine thats run a bearing
Inserted new engine
Swore a lot
got soaked in the rain
hooked up most of the things to the engine
Snapped 3 b&*#%y perished vacuum lines (and now cant remember which one went where)
make sure you use cable ties on new soft vacuum hoses
Hadnt been cleaned for about 2 months so cleaned it out and found all sorts of sh*t. a k&n filter which i brought for like $200+, found my 30pc 1/4dr set which has been missing for like a month underneath passengers seat, that came with 2 credit cards and a lighter, f*cking heaps of rubbish, nut/bolts/screws/bulbs, some poor girls shoe and jersey, a few hundreds worth of tools, screwdrivers, verniers etc, a zerosports 90mm pipe, probably 7 month old half full 30g port royal, a bob marley cd, defi gauges boost/water temp, a sander which honestly i dont know where the f*ck that came from and $2.60 haha along with a few other subbie bits and pieces.
Looks clean now :D
Sacked the mrs BH out.. on its arse now.. looks mean.. Washed my BG yesterday after 1 yrs dust on the roof and then fitted braided oil feed and new water hoses to my BC, needa make a down pipe then shes all go again.. Next weekends mission i think....
Liking the suspension then? haha. I'm gonna make mine a bit lower today too
