 kwi_fozze said:
installed walbro, tidied up amp wiring. re earthed the amp. installed ebc, basic set, gawd damn im sore now...
good to finally be doing something though!!!
driven with ebc yet?
when you putting ecu in ? curious as to results
nah, not yet. having a small drive tomortrow possibly, might have a play then. be another couple of weeks before i give it a good thrashing.
ecu i'd prefer to do then straight onto a dyno, dont want to pop the motor, as i have no backup!!! hahaha
put the Garrett back on
Still have things like ....
port matching the new throttle body
Plumbing in the EVC 6 boost controller
screwing the wideband AFR sensor in and tidying up wiring
hopefully test runs tomorrow - YAY
 WRXONP said:
hahaha i would be curious and wam it in and see what happens hahaha
what size you go for on the wastegate hoses?
4mm, the connections on the turbo are 4mm, controller are 6. may increase size to 5mm or 6mm if i can get hold of some worm type clamps to make sure it doesnt leak!!
rescued my mate, car was stuffed she said, call the scrap guys she said picked up a trailer, picked up car, jump started, and haha it goes!!!
wont take 300 for it now tho dam it!!
should of offered BEFORE you tried to start it :)
 BF5GT90 said:
do want. where did you get it from???!
i have one here
you can has for $120 plus postage
On the right in this picture
or I can add the bit on the left as well ( negates the plastic bit between the turbo and intercooler ) for another $100
well massive ups to luke (sl8r) for helping me over the weekend, we:
replaced my front two brake lines and adjusted the brackets so i never have mishaps like at manfield again
bleed all four corners with new motul rbf660
removed the room bar and strut brace
comletely stripped my dash, heater core, aircon box, the kitchen sink all out,
plugged in whats required so i can still drive the car onto the trailer
removed the fire blanket on the firewall
and chipped the remainder of the sound deadening off.
On lukes we fitted his new 21mm adjustable rear sway bar
attempted to fit the 22 front and discovered its bent :(
and removed his FMIC to strart straightening the bumper iron and straightening the FMIC up a bit
already for next weekend missions now
