 We are borg said:
moved it from my workshop to home :) was my 1956 Morris Minor still runs and drives considering it hasnt been started for over a year :)
car ute or van? i've been saying for many years my first ground up project will be a split windscreen wellside ute with a 8/71 + bug catcher out the bonnet
removed engine & g/box from the gt then tapped an old thread in the starter motor, opened g/box replaced reverse cog which was supposed to be in there, found a bent selector fork......
what was one to do but remove the engine & g/box from the RS & fit the rs's built unused g/box into the gt refitted engine plumbed up all i could remember bleed radiator & drove it, Popped my first ever intercooler pipe off too wondered why i lost boost but it kept running hahaha (link ecu) completely stoked with it 8)
will be replacing the selector fork in my good g/box (lucky i have plenty of spares) & will swap box over at later stage :)
 dacerx said:
Seriously massive efforts these cuddas
yep it was, pretty average when you know what your upto, really miss having hoists though, crawling round under jacks & stands removing bolts & stuff lying on ya back isnt much fun, but once it all done its a good feeling :)
(not the next day when you feel all the bumps, aches & scrapes tho)
Haha +1 on that cuddas ::)
Actually just brought a hoist today and set it up, the old mans got a old holden v8 that went for a swim so we just pulled the engine/gearbox out, stripping it now and putting the water pump, distributor + gearbox onto another secondhand v8 engine. Need new engine mounts and a few other bits and pieces, gaskets etc but should be in and running by late tomorrow. the old man will be happy to have the v8 back on the road ::)
 kwi_fozze said:
ecu reset, code 32 o2 sensor (intermitant)
ecu reset again, no codes, f**k me what a difference. less fuel usage, harder faster on boost, more solid bottom end, pulls MUCH harder. wee!!!! need a new 02 sensor.
done the same 2 mine, 5th full boost is sweet :D but i replaced the o2 so should be sweet, got a trip 2 wgtn this friday so wanted it 2 save abit of gas, will get some fuel usage figures from it 2
The only thing i noticed was fuel usage dropped on open road trips, power was the same (running on the dyno i've had the fault code come up after an ecu reset, no power change) i've had o2 sensor issues since i got my foz, fixed it once then its crapped out again, not worth getting a new o2 sensor for the amount of "extra" fuel i'd use. Last time i got a free o2 sensor ;)
 sultan']
4 door sedan.was my first car about 25 years ago :) has taken me this long to fully restore it :) looking at maybe an EA81 or Rotor conversion
 Enervated said:
After having my legacy for almost too years.. finally got around to fitting a pod filter.
Make sure its boxed with complete proper air supply from outside, dont want to be sucking the heat from the engine in. Factory can still perform well since its already boxed and has a good cold air supply.
Waiting for engine mounts to show up, replaced all seals incl. the mains.
