  • Replies 50
 kiwisurf said:
Can someone confirm if this works for the Bilstiens in a GTB as well????
Yeah has anyone actually done this with Bilsteins? I had a look into it and pretty sure it can be done but don't want to have shock explode or something on me if I'm wrong!
There is a nut on the bottom of the strut that can be removed and then the insert can be threaded out of the strut housing using the grove in the bottom. I found this described on some BMW forum a while ago whilst searching but cant bloody find it again.
 rico']
Yes the GTB (BG5b/c) Bilsteins can be disassembled in the same manner. i.e. undo nut at the bottom, then unscrew the shock insert from the yellow body.
the bilsteins i had have nuts on bottom . . but red struts are packed with grease. the bilsteins state on them they are under pressure and oil filled .
I just re-greased my bilsteins on the weekend (97 legacy GTB BG5B). Just remove the bottom bolt and the insert threads out.
Was some Red grease in there that had gone quite waxy so removed as much as possible with spatula and rags then put some new grease in and re-assembled everything.
Now have no knocking that I was experiencing from Left Rear and car feels so much smoother. Also fitted some Tein lowering springs at the same time so feels like a new car, stoked with the outcome!
the grease in mine had liquified in both left struts. undo the bottom nut and the carp just dribbled out. kerosene bath cleans them up nicely. make sure you get all of the old grease out!!
f**king horrible job, messy, but well worth the benifits.
Im sure exhaust heats left Rear strut and makes it fark out ? its all ways left Rear 1st . you Using those red struts yet kwi foz
  • 9 months later...
  • 3 months later...
Bit of a dredge:
I'm about to repack my bilsteins (from a BE5) with grease now.
I have the nut off of the bottom of the strut, but can't get the damn thing out of the body - i.e it won't unthread - I'm trying as hard as I can
I've tried freeing it up with Inox too, anybody got any ideads?
(I have a pic, but don't know how to attach it sorry)
Gentle tap, as it to move the threads a little? I did try that, but no avail...
Or as in gentle tap and the catridge will come out too?
Just got pissed off at them in the end and put them back together ;D
When i did my sti struts, the whole shock cartridge slid out of the sleeve (the bit that bolts to the hub) i'm not sure about bilsteins, but from what i hear they are the same?
Alas no. Instead of just pressed in there with the nut at the bottom like the STi's,
On the bilsteins there's the nut, but the bottom of the shaft is threaded (or certainly looks like that, and other commenters have said the same thing) into the the housing, once the nut is off.
Stupid thing :-\
Oohh what a c**t, good luck!!!!
What i've seen people doing in the us, drill and tap in a grease nipple between the slide surfaces on the strut base sleeve thing, jam yer grease gun on there and pump away a bit
  • 4 weeks later...
  • 4 months later...
Realise this is an old thread, but like most people on this thread my rear left bilstein shock is knocking...
Can BH/BE bilsteins be regreased??
  • 2 months later...
Yes, Just the same process.
  • 1 year later...
