Dumb Question Thread!
Jambun
 Andy_Mac said:
How do you go about becoming a club enthusiast? That back us link at the top of the page doesn't seem to do alot other than describe it.
PM: http://clubsub.org.nz/forum/member.php?446-DacerX
We are aware the website is on a bit of a loop and it will be resolved soon *touch wood*
Thanks for showing your support by choosing to be a Club Enthusiast :)
Can someone field some questions for me re turbo chargers
What's the go with exhaust housing interchangeability? E.g using a single scroll exhaust housing on a twin scroll turbo... What fits what and what is the difference between say a p18 and a p20? How does one identify an exhaust housing? And what are the common sizes about the larger sti turbos both old and new?
Edited by slystiguy
hey so my friend offered me some new semi slicks but the tyre size is 245 45 r17 and my tyre size at the moment is 215 35 r17.will these fit or is the size difference to much and will this cause any tyre wobble.cheers
245's are better suited for 8 inch wide rims. might just fit on 7.5.
215s are best fit for 7 inch wide rims. you may not have enough sidewall flex to squish the stupid wide tyres onto the 7inch rims, and it'll be a less than ideal ride.
get a set of 7.5 or 8 inch rims
stick with the 18g its bigger and spool 300rpm later. Vf22,23,24,28,29,34 and 36 can run the bb p18,20 or 25 t/s housings. Housings get bigger in that order. I imagine the vf30 and 37 housings are interchangable but no exp there. vf34 or 36 are the pick of the bunch. Basically theyre all -500cfm so stick with the 18g and make the most of moar boost with lower iat.
Might be tight for guard clearance.
1.
 sobanoodle said:
Will rear 2pot calipers fit a '96 gc8 sti or '01 wrx? Any mods required or straight bolt-on?
bump, anyone?
2. I need to shorten muffler tips (i.e wagon to sedan) - any good place in Auckland who can do quality/tidy job that wouldn't cost me a kidney? (basically cut the tip off muffler body - shorten the tip - weld the tip back on, cannot just cut a piece off the tip as it's got some engravings on it, needs to be done from another end).
Edited by sobanoodle
  • Guest locked this topic
