Dumb Question Thread!
Jambun
May as well knock out a few dumb questions in one go.
Is there any difference between V3 WRX/STi intake manifolds? I.e if I were to use either would I get the same amount of power if I went to ST on an EJ20R (with 6S, yellows, probably VF30)
Will V7 STi headers bolt directly up to an EJ20R? Or do I actually need V3/4 headers as well?
Thought I had more than that but just more things I need to consider before doing it the way I want it :cool:
Also another dumb question that likely doesn't really have an answer but what would/should I expect to get for 4x DTM convex black/machined face 19x8" with "minor-very minor" curbing? 3-4mm tread on all 4.
Edited by Skatieguy
I think the only difference between the earlier WRX/STI manifolds is the paint, with different injectors on some (yellow/grey).
Compression ratio matching (engine/ECU) is the main thing to worry about for the swap. All the info should be in the single turbo conversion thread.
Version 7 headers are a perfect fit, no change to exhaust bolting patterns.
I'd say so, it's only 20ps difference so combination of drivetrain and smaller turbo should do it.
The auto's will spool a tiny bit quicker due to the smaller turbo, but other than that the difference probably isn't too noticeable.
Looking into Adrenalin R muffler as seen on tardme. Anyone used these? Comments on sound? Want the B4 to actually start sounding like a Subaru. Oh, and Timmah, I had a "mate" who had cobra springs in his BG wagon. It sat nice, never got to give it a fang to see how she handled though…
 Andy_Mac said:
^^ just detuned like most auto subaru's.
Can't you tune the newer auto trannys to be more aggressive and less sluggish, sure i've read someone saying they've done it to theirs somewhere.
Can't tune them via ECU AFAIK. You can do valve mods to lessen the slush and give the auto a sportier feel, better shifts.
  • Guest locked this topic
