Dumb Question Thread!
Jambun
 funkytown']
[quote name='94 Leone said:
You still have 3 out of four wheels driving, better than most cars xD
if you dont have dccd that is, else you're beached like most other fools ;)
Or if u run a Leone with a Positive centre diff lock and a LSD rear Diff :)
 Johnnynz said:
If I take off my Calipers and Brake lines will the system dump all the brake fluid? Or is there some sort of valve that stops it dumping all the brake fluid.
Vice grip the brake line before u take it off the caliper
ECU question, I've looked around(and searched) but couldn't find it, I know due to gazzys TT-ST doco, he used an A8 ECU, I understand this was the ecu used in the auto v5's is there a change in the CR between the A7(manual) and A8(auto) ECU's? just a thought, didn't feel it warranted it's own thread.
Hey,need some advice to confirm or smash my assumptions.
So at the moment, when I start my car and start driving, the clutch pedal is nice and soft and the clutch basically engages as soon as I let go of the pedal.So to my knowledge that's called the clutch takes low.
When I drive around for a while pressing the pedal becomes a bit harder,almost like there's more force pushing the pedal back,and my clutch takes higher when I have the pedal almost fully released. Does this make sense or should I start drawing pictures :P
Will a clutch bleed fix this?
I would think the CR would be the same, the A8 might have a less aggressive tune since the autobox wouldn't as strong as a manual one.
 Timmah']
Yeah, that was like a midnight sh*tmyself session lol. I found gazzy's thread and reassured myself lol.
and that is not the be all and end all as well if a tire is a "snow and Ice" type ( or can be determined to be one) then it has to have 4mm of tread, this is what the WOF inspector told me about my silverstone rally tyres fitted to the RX,but we shall see as he was perplexed over them :)
ha the warrant had just been done on the forester when we swapped for it it had kinforest tires and the guy listed on the sheet that they had 4mm legal and were snow tires but they werent lol just chinese crap.
I've had a bit of a search but was unable to loctate anything but was wondering if one of those STi Keys would fit my BE legacy? I read a few things online saying they can only fit anything 01 or newer or something along those lines... I know it's cosmetic but want to get rid of my current key (with the lock/unlock) that is replaced by my alarm...
 Divine said:
If the outsides of my tires are bald, and the insides have 4mm, is that averaged out to determine if their warrantable?
i failed my warrent for just that reason last week, and it was just the corner edge too best find a pair of tyres u can borrow
  • Guest locked this topic
