Dumb Question Thread!
Jambun
I\'m prob wrong
But there\'s a bolt just tucked behind the front wheel, about 6 inches in? I use a trolley jack on that bolt, it\'s pretty solid part of the structure and the only point a trolley jack fits in on some cars anyway hahah - it\'s one of the bolts for the control arm rear bush/mount thing.
Quite likely not the right point but meh
 Marky said:
I\'m prob wrong
Works for me or tow hook at the front, often dont use axle stands as bitch to work around when doing stuff up front. For the rear I use the diff. I have special 4x2 ramps i drive on too so i can get the bliddy jack under.
I try not to, just cause half the time you end up folding the metal back which apart from looking heinous I\'ve heard can be a WOF issue? The factory jack thing has a cutout in it to avoid doing exactly that
I normally pick the most structural parts I can - like suspension mounting points tend to be the best bet - and subframe etc for axle stands
To be fair you can\'t really get it too far wrong
I\'d rather be safe than sorry. Is there a jacking point under the engine/front of the car that I can place a trolley jack to lift both front wheels at the same time? I thought there would be a jacking plate of some sort? If there is can someone advise me where exactly. Thanks.
My trolley jack doesnt lift high enough to get both wheels off the ground if i use that point (was ok with coilovers but stock shocks have too much travel)
that and it doesnt fit haha
but yes that plate with the bit of blue pen on it
In a wrx (or possibly any sub:
1:How much hp/kw atw does it take to do a 100kms/hr in 4sec (or to crack less than 5sec)
2:how much power to crack 11s in a quarter 1/4 mile
Any proof or formula to back your claim cheers
Depends if you have launch control or not, how much the car weighs, all sorts.
There was a Legacy RS that broke into the 10\'s while still running a VF22 (meaning maybe 250kw maximum) but it was completely stripped...
sub 5 sec easy if you get savage on it, 180atw would be enough - for an estimate my old vr4 which ran mid 12s clocked sub 4 0-100s
11s ballpark 250atw, depends on car, setup & driver
have seen 400kw not make it with muppet drivers
answer is: how long is a piece of string
  • Guest locked this topic
