Dumb Question Thread!
Jambun
2 dumb questions...
1. What is the marked item? Im guessing something to with ABS?
Question 2
And what is this to? Its bolted onto the stock airbox mount and apparently goes nowhere, it doesn't even appear to be blocked off.
Cool thought I was on the correct line with ABS.
Is there a need to block off the Carbon canister vent?
And also if I run a piece of piping from the front bumper (say under the indicator) up into the engine bay should I be concerned about water getting into the Airbox I plan to create?
not sure about the airbox thing man.
but people remove them and some done depends if you wana smell fuel or not.
i chose to leave mine in there just for the sake of it
 Divine said:
What really happens when you pull the handbrake in a All Wheel Drive?
i.e Ken Block videos, he uses the handbrake, but shouldn't that really mess up the center diff even with the clutch in?
As long as you have an operational centre diff (viscous or plate etc), the rear wheels will lock up (if you've got a decent handbrake) and the front wheels will rotate. The centre diff allows both ends to rotate at different speeds, in this case one ends speed is 0 rotations per second.
If your centre diff is welded solid (or you drive a Leone which only has a front and a rear diff) then when you pull on the hand brake, both rear wheels will lock and at least one of the front ones as the front diff will allow one wheel to rotate.
 Koom']
Ah excellent, well written and easy to understand, thankyou.
 Koom']
hehee except the Leones hand brake works on the front wheels :) but same applies
  • Guest locked this topic
