Thats the p1 filter by memory well by listings anyway. I did have the gen numbers somewhere but p2 take a smaller filter not sure on the ryco number but its a C8036 in sakura. Worthy of note that if buying sakura you will probably be supplied a C1032 use a C1816 instead the C1032 is sometimes a bit short on the thread.
I personally run the small one but thats just coz Im pedantic. Biggers probably better/longer lasting etc but I change every 5000km anyway.
Fucked around forever trying to get a toggle switch to work for launch control. Wired per g4 diagram couldnt get it to work regardless of settings and how it was earthed. Then had the bright idea to use air con switch took 2 minutes to set it all up. Just got to get settings right now.
It is wired to speed...I dont want it on permenantly so I need a switch to turn it on or off also. A/c switch was set up for air con request from stock I just had to set it to g/p for the right output.
Jon you got time to be on here arent you losing your man card next few days?
New oil + filter today and a wash too
After tuesday I will finally have more space in the garage, so on wednesday I am picking up a closed-deck engine and a VF22.
At this stage will just be forgies and cams using my STi heads, in the future might look to a bigger turbo as I\'m aiming for 400whp and don\'t really want to accept less than 350, but we\'ll see how it goes.
