 dubbedup']
[quote name='jacsmiley said:
size=3]STRIPPED/LOST 2ND GEAR[/size] >:(
its alright...you can just drive around it :P;) ::)
haha yeah its not too bad as the typeR has close enough ratios to skip 2nd but its damaged 3rd syncro and needs time to engage. aahh well cant expect it to hold up forever driving it the way i do ;D
Guest Fastfour
 dubbedup said:
haha we prolly need a thread: those that cannot make a gearbox last more than 6months at a time :P
Shoosh you!
Removed the Tail lights for the tailgatge on the Legacy to try and stop them filling up with water. Sealed them up with silicon.
I then started on the Leone coupe as it leaks water in around the tail lights also.
 keltik said:
Drained some aluminum slurry out of my gearbox.
Pics cos i know you all like to see these things;
No, I wiped the metal shavings off....THEN put the bung back in and stuck some oil in it. Its only got to last 4 more weeks before replacement.
Im just hoping all the chewed up bits left in the bottom of the drain pan arent important ;)
 keltik']
Ha ha thats pretty much what mine looked like when I did the oil before blowing the box last time.
Guest loren
radiator flush, and change of bottom hose.
what a painful job, heat up, drain, refill, heat up, drain, refill, heat up, drain, refill, heat up.
did some work on my car today
plan was to swap rear rotors/pads & full flush, change oil, swap center diff.
when putting the rear brakes together we realized they were the wrong size rotors. :'(
took inter cooler & downpipes off then seen the gearbox mounts were fucked so didn't go any further about swapping the center diff, refitted everything :'(
changed the oil.
Filled up the water and seen i had a split in the radiator :'(
oil change took about 3 hours :-[
