Marked, Cut, Drilled, Plate & alloy strap to mount battery into boot. Bolted battery box into boot and have run battery wire thru cabin to dash ready to be attached to 12v kill switch when dash and everything is installed. Best thing is the battery wire I have is Blue so its already Subaru coloured!
Have cut out a panel to be bent up to cover the gap between radiator and its mounting point.
Shopping tomorrow for more P clips to hold battery wire to cabin floor & a bunch of other small bits and pieces.
Finished Spraying the engine bay, just got to cut a couple of alloy plates to cover holes then refit all the bits I pulled out of the way to spray it. Isn\'t anywhere near show car quality as I couldn\'t be arsed to drop the engine and smoothe everything over etc looks better than it did though so happy enough.
 Ninja 8)']
[quote name='evowrx said:
Is that marcs old TD06?
Sure is! And so is the sump. Still yet to be paid for so really its still his.
On abit of a roll spencer! You better make it to the dyno this time!!! No excues haha. Oh and a track day or two ::)
I set spark plugs and put a 2.5inch up pipe on my 99 STI RA.
goes way better, took it for a drive with no centre or rear exhaust, reall loud lots of turbo noise and screams when ya pin it.
goes best from 80km/h and then slip it into 2nd and pop the clutch. much fun!!
 marc']
Sure will! Squriell ate all his acorns already!
Anyone interested in a VF30? Has the usual slight crack by wastegate port. Approx 140thou kms
