So confused, why do I have an intake leak
Oh wait
Fixed that problem by installing a new gasket, or so I thought
That then continued to leak, reason for that it turns out was one of the bolts I used (the one in the most bastard location at the back) was the wrong one and had grabbed maybe a single turn of thread.... Before stripping the thread in the block. Unbeknownst to me.
Longer bolt found, problem solved, inlet manifold clamped down evenly, no more pheeeeeEEEEEEEEEEEp noise on boost, yuss
Also made a proper pipe for air filter (replacing skody corrugated one)
Edited by Marky
 94 Leone said:
did my last service on the wrx before the cambelt change, also only 800 of the loan to go now. checked the cv's as to my knocking noise: no play of cv's, pretty sure it might be poked struts. or on their way.
now: do I go coilovers and cert... or new struts, dont really wanna get coilovers before ive got the 17x8's I want though, as im not overly keen on the re-cert cost lol
I have a set of struts they look to be good condition red ones in the front and standard black in the rear i won't be using seeing i have bc's going in the Wagon pm me if you get stuck!
Painted the roof vent
Replaced smokey vf23 with vf22 that Johnnynz kindly picked up for me from auckland..
Took it for a 100 k drive around the pohangina valley..
Laid down a solid smoke screen for first 50 k as the exhaust burnt out the oil and crap..
Came clean and is running well and boosting fine..
Nice to have it back on the road again..
 McDoof said:
Changed the oil and filter. Oil fumoto oil drain plug to make these things easier in the future
Didn't Matt mention a while back he prefers to tune for oil thats had a bit of use so the tune isn't done for a car with perfect condition oil which it'll hardly ever be in?
Lol because oil goes from good to bad in the 10000km between changes. Sounds like john deere oh any competitors oil only meets spec for a week use ours. Yea because thats how oil specs are measured on a 7 day interval...
 DRFVDR said:
Removed the fuel tank from the RX, will give it a good clean out today, trying to fix a fueling issue, new pump and relay and still same issue, there was some crap in the tank so i am hoping that it was blocking the pickup
Ya rx lives again!
