I still haven't got mine done, as the car has been out of action for most of this year. Only booking i could get at wingers was for mid Jan next year. How unsafe is it running around with them in there in this summer heat?
Share this post
Link to post
As long as you don’t crash into something and nobody crashes into you,you shouldn’t have any problems.
Share this post
Link to post
Well your car is probably at least 10 years old, so I don't think another couple of months is going to make any difference. Aren't there about 3 instances of them exploding out of about 5 million of these airbags out there?? You've probably got more chance of winning lotto.
Share this post
Link to post
5 hours ago, BMCracer said:
And they obviously don't care about their authorised workshops doing sub standard work either, because they can't be bothered to reply to me.
So if you need to get your airbag replaced, stay clear or Winger Sublab in East Tamaki. That's who did mine and made a complete mess of the car.
Decided to make a dealer/service centre review thread so people can easily see reviews etc. Feel free to dump your story on there.
Share this post
Link to post
You should email/call this guy at Subaru NZ.  Wasn't much help with my sticky dashboard issue.  But you may get better luck.
Andrew Lov
andrew.lov@subaru.co.nz
Customer Experience Specialist
DDI: (+64) 9 272 7743
Share this post
Link to post
Andrew Lov
Awesome! @BMCracer give him a call/email and keep us posted.
Share this post
Link to post
Shouldn't that guy be where the feedback page on the Subaru NZ website goes to? In which case he's already got the message I sent to Subaru NZ last week..........
Share this post
Link to post
They could already be on holiday? Awkward time of year for this to happen to you.
Just to give you an idea of their response times, I've looked back in my emails when I reached out to Subaru NZ via their website... I submitted a contact form on Thursday 9th August and they didn't reply until Friday 17th.
Share this post
Link to post
On ‎11‎/‎12‎/‎2018 at 3:48 PM, BMCracer said:
It looks like the filthy pricks had just done a suspension job and then got straight onto my car - without washing their hands first. So the A pillar trim on both sides is covered in dirty greasy hand prints all up and down both sides...…..
I looked around here and a couple of other places, and couldn't find a product that was definitely proven to get stuff clean without leaving stains or discolouring it. So I took a punt and tried some Rug Doctor strain remover I had at home for the carpet. Worked a treat!! Spray it on both A pillar trims evenly, leave for a couple of minutes, then lightly scrub in circular pattern with a toothbrush, then rinse off. Had to do each trim piece twice to get all the greasy marks off, but now they are good as new. So this stuff works and doesn't discolour the trim.
32542024418_d76606310f_k.jpgIMG_2277 by Andrew Metford, on Flickr
Edited by BMCracer
Spelling
Share this post
Link to post
It keeps getting worse. Started yesterday afternoon on the car's annual Christmas cleanup. Found 2 screws down between the tunnel and the passengers seat, so some parts somewhere in the dash haven't been screwed back in properly. Then when I was cleaning the back seat ( dust - I've never used it ) there are 2 cuts in the left door trim, and a dent mark in the right arm rest part!!!!!!!!!!!!!!!!!!!!!! :mad::mad:  None of these were there the last time I cleaned the back which was before the airbag got done. So they obviously use the back seat to store stuff when they are doing the airbag job, and just fire stuff in there. So f***ing pissed off with these c***s :mad::mad::mad::mad:
Pulled the gear lever trim ring out, and sure enough they'd tried to put it in the wrong way which is why it wasn't sitting down correctly at the front. When I had that out, oh look, the tunnel side pieces go over the tunnel behind the gear lever and screw down to keep it all nice and tight. Except when they don't put the screws back in :mad: That's probably half the reason why the AUX cable is hanging out the side of the tunnel trim too. While I was sorting that out and tucking the cable in properly, I found ANOTHER trim screw sitting on the tunnel under the black gearlever selector piece ( the round black bit with PRND etc on it ). So once I'd put it all back together and all the screws back in, I've still got 2 screws left over, so they are from somewhere other than the stereo / centre console area. Guess I'll find out where when I pull the whole dash one day to check the replacement airbag is actually bolted in with all its' bolts.
The absolute incompetence of the peanut that did my car is just unbelievable. It's also unbelievable they still have a job if this I how they give cars back to people. So if you have even the slightest regard for your car, NEVER GO TO WINGER SUBLAB EAST TAMAKI, because they sure as hell don't.
Edited by BMCracer
Share this post
Link to post
Man @BMCracer that's just disgusting. I'd be driving there and parking across the entry to the workshop until a manager came to speak to me.
I honestly hope you are compensated for the damage they caused.
Share this post
Link to post
Finally got my letter for the Airbag, however theres a couple more recalls listed
Fuel pump harness needs to be inspected, and secondary air pump relay needs to be replaced.
Wish they would do the sticky/cracking dash while they're at it, however they haven't admitted to that one.
Share this post
Link to post
I also got my recall today for the 2010 Legacy, Knew the passenger airbag was a recall but apparently the electronic park brake is also going to be replaced or some part of it as that a recall as well????
Fingers crossed they don't break the dash or leave it in a s*** condition will be taking a lot of photos before it goes in,.
Share this post
Link to post
The electronic park brake is a separate recall but they'll do it at the same time.
Quote
A capacitor on the circuit board and/or the actuator stroke sensor magnetic ring, which is in the control unit of the electronic parking brake, may crack over time.
If either component cracks, the brake warning lamp lights up, but the parking brake may not engage. If the transmission is not in the recommended gear when the vehicle is parked and the emergency brake does not engage, the vehicle could roll away.
Share this post
Link to post
Sweet, just spoke to armstrongs in Christchurch and its all booked in for Monday.
Has anyone had their car done at Armstrongs Christchurch and if so were you happy with the job they did? They told me they for my 5th Gen legacy they will need to remove the whole dash to replace the passenger airbag so fingers crossed nothing get damaged as they do that!
The park break recall is a new one as well and they have only just got the parts for that in.
Share this post
Link to post
Take photos, lots of photos of your dash and pillar trim prior, just to be safe.
Edited by Timmah
Share this post
Link to post
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
