Dumb Question Thread!
Jambun
It\'s alright marky. though lower boost than normal is still an issue: likely to be a boost leak, i.e. fix by tightening hose clamps/apply more duct tape. does it blow black smoke under boost? if not then, you are likely to not have a boost leak.
 B4 I was 250T said:
Mmmm, does seem that way but it is genuine straight from Japan HKS. Surely that should mean something...shouldn\'t it? The ones on youtube sound good and Redline are one of our sponsors and they support/sell HKS..... ???
If you can see your SSQV, can you see 2 big hoses attached to it, then a small one? What 94 Leone means that instead of your blow off vale dumping the air into the engine bay, giving your the psshhh sound, the air is now being plumed back into your intake and silencing things.
The blow off valves function is to release air to prevent the Turbo from stalling on throttle closure during gear shift
The hks one will do this very well
Its function is not to make gay noises . This is a by product of its function
Car manufacturers put a lot of effort into making the intake quiet . Put a pod filter on it and you\'ll hear it . Or vent it to atmosphere if your fully hektik
 Codex said:
Dynamite signage in town are pro and very well priced, Divine. I\'d either find a pdf of what you are after pre-vectored or they can recreate it then apply it.
I\'ve been wanting the stickers on my rims replaced for a while and I\'ll give these guys a try. Cheers!
 Koom']
[quote name='paulngui said:
What would cause my windows to go up and down slowly? Worn motors? Parts needing lubrication or something?
Dirty contacts in the switches. Easy to remove and clean.
Yup was going to say this, have done this a few times now and works a treat.
 Codex']
Sweet thanks, will give that a try.
no looks like the dust gaurd (black plsatic insert over the shaft) is just on the piss. they float when the shock doesnt have load on it.
probly sweet as.
also to the SSQV question earlier - you can remove the trumpet insert - and have it venting and they make almost no sound at all as well.
  • Guest locked this topic
