Dumb Question Thread!
Jambun
 kamineko said:
your one looks to have more \'kink\' than the usual front brace. maybe it is for the rear after all?
Yeah that\'s why I am a bit puzzled.. It does fit on a rear crossmember, will check tomorrow if it fits on a front one (silly me didn\'t think about that until I got home and started searching).
My initial question was whether I put on front or rear side of the rear crossmember. May be guru Marky would know
 sobanoodle']
should be the rear side. the front side of the rear-crossmember will be close to the fueltank
K brace only fits to the rear of the front-crossmember, as will that part. the illustration you have is not suby.
Squeaky front swaybar
I know it is because I\'ve sprayed all sorts of everything into the poly bush and it shuts up until the next time it rains or I look at it funny
Best fix is to: a) buy a new mount you cheapskate or b) insert substance X into the bush
Second question: is there any benefit to replacing swaybar endlinks with alloy ones other than "they wont break" - do the factory ones flex and "dull" things at all?
 Marky']
^^ No eye deer man
translation? :P
[quote name='funkytown said:
Nick... that brace is for the later model mcpherson rear end.
Not sure if factored into your thinking. Afaik there are those braces for this type rear end arrangemeng
ah.... the new stuff. i didn\'t see that mentioned in OPs post. runsaway!
Hi
a great noob question....
Waste Gate question:
If one was running a external waste gate with a 7 psi spring however the standard boost for the car was 13psi for instance would the car only boost to 7 psi or would it still continue to 13psi. The waste gate in this scenario is not being controlled by a electronic boost controller or boost tap and the ecu is standard.
I am aware that the spring dictates the lowest boost the car will run.
Cheers guys/girl
It will run 7 psi if you have set it up to run wastegate pressure. Any form of boost control introduced will raise the boost pressure. I don\'t think it is a good idea to run an external waste with a boost controller that you cannot adjust.
When I switched from my internal wastegate to an external wastegate. The boost was raised about 2-3 psi with no adjustment made to the boost controller. I had to dial that back down with my electronic boost controller.
One fun fact that I learned is that if you run wastegate pressure and a screamer pipe you can hear that the wastegate is opening much sooner than what the spring is set for. I.E. with my 11 psi spring I could here the screamer as early as 4 psi.
well have you hooked the stock boost controll to the waste gate ?
id say its not advisable . due to a far different ratio of actuator area / valve area and the fact the stock controll is blind/dumb/ doesnt know what its doing or trying to achieve , just bleeds a set amount
it will boost what the spring says it will + what ever you bleed off with a controller .
all wastegates do this . as the valve has to be fully open at 11 psi so cracks at 4 . can be negated with a ball and spring boost controller . can be totally avoided with a good ebc or a "pressure regulator " for boost controll
I was carjamming my car and it has come up in red with "at least 1 alert" Car is paid off etc and I was wondering if anyone knows what comes up on the Carjam report you pay for?
I\'m curios what it is and slightly worried the bank may not have removed there interest in it after the loan was paid.
I think CarJam only updates their records when someone buys a report for that car. Don\'t quote me on that though.
Hey,
Just curious ( pretty sure i know the answer )
but do 1993 wrx gc8\'s have a low fuel light?
owned the car for a while now and it never comes on. just thinking maybe the bulb is blown? or it doesnt have a fuel light ( but im sure it would o.O
 syneptik said:
Hey,
I think it\'s v4 or v5+ that got a fuel light.
I have a 1997/v3. no fuel light.
I know on my v5 the only time I have seen it the gauge was so low I was convinced I wasnt going to make it to the petrol station 2km down the road just before it came on. And then it stayed on for two full tanks after that lol.
  • Guest locked this topic
