 loren']
Motor will have to come out .. again :/
why?
leaking aftermarket sump (at the rear by subframe), rocker cover leaking, new uppipe flanges will have to be fab'd up, new shrouding / cooling set up to go in the front of the car.
with the things that need doing it will be easiest for the motor to come out i think.
[quote name='deathz0r said:
Got the beast a WoF. :D
Oh and installed Funky's 3 point harness. Bout to install STi seats in teh weekend and fresh oil
its a 4 pt you n00b
 funkytown said:
Gazzy - brutal buddy, thats a sad BG..
went to change the up pipe gasket last night to find its totally gone.. nudda left :S
removed three bolt(s) flange, undid headers off heads and removed to find the flange is EPICLY warped :@!! fffffffff!
no way i can put a gasket back in there as its munted. Back to the drawing board to get a new one made i guess in something thicker.
Best solution is to not use gaskets.... take headers & up-pipe off and get both surfaces faced so they are perfectly flat then you shouldnt have any issues. Thats how I run my header to up-pipe join...
Not so much what ive done to my car today, more what has happened over the last 4 weeks.
took car to mechanic with noise in drivetrain, horrible rattling/grinding noise guessing that its a universal joint in the driveshaft.
Mechanic cant figure it out, takes it to a second mechanic who says its a cheap aftermarket clutch that has given up.
Replace 1/2 worn Exedy clutch with new Exedy clutch, noise persists.
1st mechanic checks all diff fluids looking for metal shavings etc, all mint.
2nd Mechanic who suggested the clutch then suggests its a shaft/bearing in the back of the gearbox.
1st mechanic is weary of 2nd mechanic at this point and asks for a 3rd opinion.
Car goes to 3rd MEchanic who has never heard that noise before and is baffled.
While taking car off the hoist the 3rd mechanics apprentice says " what the fuck is that?"
It was jammed stones/gravel in the bracket for teh driveshaft.
Thanks Apprentice, i owe you a box of beers!
being a mechanic i replaced the cat on my type r with a 3 inch downpipe however driving it home didnt really make any difference still extremely impressed with the power anyway but thought i would make it breath a little easier and peeps say you get 20hp more however i must admit ive noticed nothing. ;)
 Tony']
Do that plus get a groove machined in one side for a fire ring.
 gazzy2000']
[quote name='mattapo said:
Finaly got round to fitting my new bits, pink top feed injectors, v7 intake manifold, swapped the exhaust manifold for a non leaking one, changed down pipe, new turbo, new intercooler and fitted the under engine plate
Lookin AWESOME man!
 Koom']
how do you mean? I'm all ears
 funkytown']
Possibly called an exhaust "crush ring"
When I've had to pick them up I have just walked into Edge Performance down here (Speedway Shop) and asked for the right diameter of one of "those" and pointed to the ring things on the wall behind the counter.
Same principle as o-ring's for headgasket issues. Just takes a groove that's about 3/4 the depth of the ring so it gets crushed when you tighten up the flanges.
picked up a few things from the powdercoaters this morning thought they turned out quite well, just gotta put them back on over next day or so and get ready for tuning on 20th. the manifold has been drilled and tapped on the runners for the port injection nozzles so will see how that goes.
