 mattapo']
[quote name='WRXONP said:
oh ok i def saw it when it was green with WRXONP plates on it :P
I saw that quite a bit in tauranga when i was up there a year back
^ This
Clearly remember you boosting off from BP Maungatapu
Got engine out, YUSS!!!
Got head off,(was some water in there :/ (probably condensation from the open inlet.)
Checked the other head for water, was none; went to tighten it back up, and snapped off a rocker cover bolt in there - yay D,: -
Took a photo; will upload soon.
Got a screw extractor?
Yeah After breaking a few bolts I have started using a torque wrench on every bolt,I have a generic torque table so it gives me a good idea as to how tight they should go.
I also had to spend some money on torque wrenches now have 4 so i can go from 10nm thru to 450nm and from 1/4" to 3/4" drive ( probably about $1000 worth of torque wrenches)
I broke one rocker cover bolt on my RS when i did the headgaskets.
And that was using a torque wrench.
Thank christ it was not nipped in the bottom of the threads..
Used the old trick of drilling two small holes in the end of the bolt and used small screwdriver to remove..
I said to dad maybe he should do the tightening from now on haha (especially with annoying finnicky little things-He has the wisdom of having broken it all before, so he knows their limits lol) but drill and Easy outs usually get them out hassle free.
Picked up the RS from epically failing its first WOF in three years ;D
Now to make a start on the to do list.....
(Although most things on the list will be ticked off by just getting it certed)
 resurrection.inc said:
changed the plugs in the sti well showed the mrs how to she was keen to do it. so she was able to do it easily. and this is a girl that says i like that blue car!!!!
I must acquire the tools and knowledge on how to change spark plugs if a female can do it.
upgraded the 4l engine mounted meth injection tank to a 12l boot mounted tank, ordered the twinscroll sump,pickup etc will be here by the weekend, sorted a date for the power tune hoping the 2.25 breaks the 300kw mark easier than old 2.0
Ordered new mirror to replace the one kicked off by drunk people a week or so ago.
Tried to decide whether tiny dent in bonnet from same people is worth getting fixed.
Found that one of the shocks in the rear of the foz is actually from a different vehicle and needs replacing anyway...
