 kwi_fozze said:
cusco k brace installed. looks gooooooood. also stuck the v10 wheels on, (with the crappy tyres on them) and jacked the pressure up to 50psi. very twitchy now, should be a whole lot of fun tomorrow!!!!!!
50PSI?? Isn't that like... a lot?
Found out I might need a new clutch >__< WOnder if something in my hearbox is playing up to wear it out, when marc put the new engine in he reckoned it still had a bit of meat left that shoudl last me a while, but it seems that sometimes in 4th or 5th gear if i put my foot down from 2500 rpm, when the turbo spools to full boost a little after 3k it either hesitates or goes up 500rpm then back down to normal and pulls normally.
New catch can setup... now using a catch can with a breather rather than routing back to the intake.
Couldn't find any nice catch cans in Wellington so made one out of an aluminium drink bottle,
brass hose tails, "need it steel" and race tape. Better than a plastic coke bottle at least.
Finally managed to get to the bottom of my CEL (Camshaft position sensor) which has been popping up since the engine transplant under high boost. Turned out to be dodgy turbo timer wiring from my good old mechanic who has struck yet again...! Prick!
I'm still finding issues over a year and a half later... Found a vacuum hose left unplumbed, unused mounting brackets he left on the engine, stripped bolts, power steering pipes crammed into the engine bay to suit V7 conversion! All of this on top of the rebuilt gearbox which lasted less than 1000 km's and the axle nut which was left off entirely when car was sent to be dyno'd, it was driven without the nut and then dyno'd before tuner noticed the sound of the axle shredding the hub to pieces...!
The thing that annoys me is I was more than prepared to pay for a top job and I did, but sadly the workmanship is just pathetic especially considering what it cost! Bloody useless in my opinion!
Choose your mechanic (in Tauranga) carefully...
Gave them a clean and a good spirited drive which was followed by a visit from a Highway patrol officer after someone called *555 on me...!
Edited by scooby-wrx
Placed new clutch and flywheel in, and put the gearbox back in the car after the repair of the bell housing. First time doing this and learned a lot, does help to have access to a Subaru expert if needed and a professional garage with hoist and tools.
Pretty sure the Chinese clutch that was previously in there would have slipped a lot towards the end of its 2000km life only had 1400lbs of clapping force, now changed out for a 3500lb clamping force, sti clutch with Kevlar 6 puk disc built by auto clutch.
just found out i took out the 4wd class at the gymkhana on sunday. stoaked. few bugs to iron out, k brace has a little movement, i was faster on the ****ty tyres, and the VTA BOV is making me slower. changes to be made for next time!!!! i broadsided a cone on my first run.... yeesh its going to be a slut to buff the marks out. no panel damage, just a little paint rub.
