Dumb Question Thread!
Jambun
workmate bought a car and he said he wasn't running right i said to check for fault codes by plugging up the green and black plugs and check for codes now the plugs were already connected and the check engine light bulb as been removed.
So my question is would this of done any damage to the car?
If its just water it'll disappear once you're up to temp and just evaporate away. You probably won't get it it hot enough to burn off any oil vapour/residue that may be present inside the exhaust. That could be caused by alsorts of things. Does it smoke when you're driving it? Have to top up the oil regularly?
Also, are you talking about inside the exhaust or outside? Cause outside is just all the seals on the engine leaking.
On the outside when I lie down and look under it.
Fresh oil flush and change 1000k's ago.
No smoke when driving.
Might have to go seal replacement crazy on it, if I had the money I would love to have the whole engine stripped down, cleaned and reassembled.
 xsvpwr said:
on my old legacy the rocker covers used to seep oil down on to the headers
Our 2001 Blitzen sedan is doing the same thing i thnk? Used to be a strong smell fron engine bay only after extended uphill driving but now does it after almost every drive. Keeping an eye on the oil level and all seems well but I'm guessing its such a tiny leak its barely noticeable? Mechanical warranty with only $150 excess so really should get it seen to sooner than later.
  • Guest locked this topic
