Dumb Question Thread!
Jambun
 ADIKT said:
Going to try change downpipe. However looking at the standard one - looks like there some sort of sensor sticking in the cat? Like a temp sensor. It is not the 02 sensor. What do I do with this sensor
measure resistance, unplug sensor, biff resistor into the plug and win. or, get a nut welded to the new dp and screw the sensor into it.
 kwi_fozze']
hmmm
 jimme18 said:
limits injectors? so u cant upgrade to yellows or higher? it just seems like a good cheap tuining tool rather than spending 2000 on g4 plus tune!
They apparently only handle up to about 850cc which is still enough for around 300wkw.
And a tune for a Link will cost you more or less the same whether it\'s a LEM G1 or a G4+.
Unless the tuner charges you more for making him tune your dinosaur gear.
 boon']
650cc seems to be the figure thrown around the webs but I have no exp with them other than eyeballing one.
  • Guest locked this topic
