 funkytown said:
what are you doing with that? - is that a factory OEM peice or aftermarket
I will be putting it in my BL legy to get rid of the SHITTY JDM factory unit.
Pretty sure its aftermarket. The same guy sells them brand new for $850 on trademe.. this one has a couple MINOR scratches..
the heater controls are a genuine though
 ADIKT']
I will be putting it in my BL legy to get rid of the s***TY JDM factory unit.
Didn\'t you buy that ages ago? Took a while to get it if so
 paulngui']
i did. Took about a week. Now the test to see if a head unit fits perfectly or if it needs mods
 ADIKT']
Oh yup, not too bad then. Just feels like a long time since you won the auction.
Yesterday had windscreen replaced.
Now just have to get it in to a panel beater or someone to get the sunroof fixed (some tool stood/sat on it while i was at the races in Dunedin and one side isn\'t closing properly, leaks like a sieve in any decent rain)
managed to upset my cam timing bi like 4 teeth each on the passenger side cam trying to inspect cambelt ffs
upon inspection belt is fine but the toothed idler is not ideal
does anyone know what colour all the idlers are from factory
mine had a red one 2 black anf the tensioner was blue , talking bout seals on bearings. seems strange ?
remove fuel pump in leu of DW 200
weld wideband 02 boss in dump pipe
dummy fit water inter cooler for fully sick ice water set up for drags
Colour of seals on bearings means nothing they are different from manufacturer to manufacturer.
Pics of water to air and whats the vehicle?
Saved my new engine today, here\'s my $300 gates racing kevlar timing belt 5000km\'s after the rebuild. My Tomei belt guide was rubbing on the back of the belt. The crazy thing is the belt and the guide was installed by my engine builder. Just replaced it with a bosch one as need it for work.
The belt guide had no adjustment but still bad form from the builder to fit it with no clearance
also dropped an extra shim in my oil pump so running a 4-5 psi more pressure
Jeeeeezus... good catch :o
 boon']
img]http://img820.imageshack.us/img820/1269/img029z.jpg[/img]
Gates sell a tool theyve just bought out that slips between belt and guide to ensure this doesnt happen. Was in motor equip news few months back. Oy you can slip in a piece of cardboard or whatever. Obviously not naming the engine builder...? Why did you check it? To do the oil pump shim?
I just use a piece of cardboard, the tomei guide has no adjustment so the engine builder should have questioned the lack of clearance. not naming them but i will be calling them today.
I was in there to move my cam timing back to factory settings as it was dialled in on different centreline and lacking in low end torque. need a retune to see how well it worked
You mean there was no slop at all in the guide?
