Dumb Question Thread!
Jambun
 pedro said:
Has anyone bought a cambelt kit from Partsouq for ej20 v4..If so ,how much and do you have part numbers ??
Im pretty sure ive got them will check when home. Only difference between early and late is the auto tensioner.
Sweet. :) Another option is to remove the pillar panel and try to get the hose down beside the dash, but it's pretty awkward. Also probably need to cut/file a notch in the base of the panel to not pinch the hose when it clips back on:
Radiator caps, I think I've asked before, but can't find the answer. But.. What do I need? 1.1, 1.3, 1.9? Iv'e read the header tank, and rad have different pressure caps? 1.3 rad and 1.1 for header? is this right for a ej207 & aftermarket aluminium radiator?
:confused: Subaru parts list two types - Coolant recovery cap & System coolant cap?
Edited by Disruptz
It's an open system with common pressure everywhere so they should all match. I think standard is 1.1 bar.
If you have a 1.1 bar on the header tank and a 1.3 on the rad you may as well weld the rad shut because the header tank will open instead.
My factory caps are different. 113kpa at header vs 137kpa at radiator :/
 sobanoodle']If I can get them for "a bit over 20nz" each that won't be bad at all, Partsouq shipped is about NZ$135. Will check with my local BNT on Tuesday.
www.ebay.com/itm/4-X-NGK-Laser-Iridium-Resistor-Performance-Power-Spark-Plugs-ILFR6B-6481-/251913236422?hash=item3aa732efc6&vxp=mtr
About $72 delivered via ebay.
[quote name='tydon said:
where can i buy replacement studs and are they as easy as twisting them in?
I think you can get them at Repco?
Or try a fasteners shop like EDL or Blackwoods etc. But you need to know both thread pitches and lengths.
To install them, put two nuts onto them that you tighten against each other, then use them as the head to screw in as you would with a bolt. They don't need to be overly tight either.
Edited by Koom
  • Guest locked this topic
