Dumb Question Thread!
Jambun
Its weird, the noise doesnt seem louder using the screwdriver stethoscope method... Maybe im paranoid. But it was definitely loud last night after a 400+ Km trip.
Might still grab a new turbo in case.
Lolat monster teach on wrong setting . Knew someone with a old blue flame engine . Think its a chev . Like a 4 litre 6 and the engine is like a metre tall . Swore it was a race engine that did 9 k rpm . Think it\'d be lucky to do 6 k but it\'d make sense . Have also heard of hooking the boost gauge to fuel pressure to be fully hektik
Please hold caller...a couple of weeks I can tell you. But V5-9 will bolt up at least. The throttle cable tab things hit the mani though. Stoffa, mattapo, tez n u did it. Mattapo used a 3mm spacer iirc but theres a write up on here.
The V7 sti one Im using is still slightly unequal but TB position is far better for flipping/top feed/etc.
Guest hate-evoz
sometimes the chain stretches or tensioner needs to be replace because it becomes loose. if it needs to be changed i say do it but not cumpolsury if the cars running ok. check compression would be best way to see if engines in a good state
Guest hate-evoz
you will know if the chain is stretched because it will make a distinct ticking noise similar to a noisey tappit
 paulngui said:
Do chain driven cars still have a \'major\' 100k service? By major, obviously not to the extent of those with cambelts but still somewhat more significant than normal services
Yes
plugs,oil,oil filter,fuel filter,air filter, at least, coolant maybe I am sure there will be a list somewhere :)
 We are borg']
Yes
Yep coolant too. As well as Gearbox oil and diff oil.
yeah; they can; You can get spark plug cleaners: go into your compressor: you can also wire brush them if they\'ve been fouled. and electrical cleaner would be fine: or anything really: if it\'s being dried off, it\'s not gonna do any harm.
 Timmah said:
Can spark plugs be cleaned? As in nuke them in electrical contact cleaner and let them dry?
Hitting them with a gas torch will clean them up, all spark plugs have a self cleaning function that comes in when they get hot enough. Be careful not to over heat.
After that file the electrode flat (if needed) and re-gap.
I find the easiest way is to let them sit in petrol for half an hour then wipe with a clean rag if you don\'t have a gas plant handy.
Stay away from wire brushes, they create tiny scratches on the electrode and earth strap that can mess with the plug (apparently)
  • Guest locked this topic
