Dumb Question Thread!
Jambun
 chulozumo']
[quote name='evowrx said:
Is that an RX6 or whatever housing? Those IHI or whatever prodrive thingymabob turbos.
It\'s a wrc rx6 ;D looked pretty crazy I person! Saw it down at FFS the other day..
Was I correct? Like what Emma Gilmour runs ae?
I thought it was a spicy one, the little port in the front is for a compressor speed sensor which is some high-tech shizzle right there.
Pretty sure the WRC cars use that for boost control instead of a pressure signal.
anyone tried the aftermarket top mount intercoolers for gc8 off ebay.im talking about the chinese made ones.same as the ones autobahn88 supply on ebay.they say they are direct bolt on but the core is 30mm thicker than standard.so wouldnt that mean the red 90° elbow that connects to the compressor outlet will sit 30mm lower.meaning it wont really bolt up using my factory y pipe..would rather one of these than the front mount setup
Are you talking about one like mine?
What version GC8, V5-V6 is easy enough to fit a V7/8 STI TMIC.
Others have done it on earlier versions to but its hard I think.
You see them for a lot of n/a motors - esp. a lot of hondas & suzukis and the like
I think the theory is similar to expansion chambers in dirtbike exhausts? (but... in reverse) or something - something to do with (as said) intake velocity or whatnot
  • Guest locked this topic
