Dumb Question Thread!
Jambun
Clutch slip is when you\'re in gear, you put your foot down and the revs go high before the car moves? I was going onto the highway, shifted into third, foot down, car sat at 60 revs skyrockted to 4k before I went anywhere.
 boon']
[quote name='QRAF said:
NFI, but several of the WRC cars have used them (I think they call them "velocity chambers") so they probably do something useful.
are these kinda like inlet resonators when I owned a Toyota soarer it had something like that
http://planetsoarer.com/resonator/resonator.html
or is it something different
one is designed by yamaha and prolly has significant RnD put into it and works well .
the other is a tin can from a shed in h town or whangas .
thats interesting reading about the soarer stuff .
although the soarer stuff seems to confuse pre and post throttle body discussion
i was under the impression that most of them are to quieten noise eg dampen a particular frequncy etc to prevent intake drone ( have since read this is a common misconception)
I get lols from stuff you write (re tin can)
- I remember reading another dyno test thing, might have been in HPi or something - same idea, they used different sized resonators on the inlet to like a mirage/corolla or something - had similar results. They could gain or lose power at different points just by changing the size or the resonant chamber - I think a massive 5l jerrycan gave the best but did lead to some issues with room
Though to be fair making 5kw on a 50kW car I\'d rather just have the extra noise and take the placebo effect instead haha
Doort dooooort bwaaaaaaaaarp *50kph* bwaaaaaaaaaaaaaaaaaaaarp *80* meanwhile getting passed by a half laden bus
 paulngui said:
Not necessarily a dumb question, just don\'t wna start a new thread, but if I want to buy a towbar off Trademe, who do I go to in Auckland to get it installed?
have seen people install themselves. Do it yourself? If not any mechanic place should be able to do it. Shouldn\'t be a hard job
yeah they are made to just bolt on . and maybe trim the bumper etc depending on exact fit etc .
might have to drill holes in something .
its be pretty simple . youd need a 1/2 inch socket set to do it up porperly .
someone will do it for a box of beers if your not so keen
 Marky said:
http://www.iaperformance.com/product_info.php?products_id=2580 <-- A USDM - JDM conversion kit thingy?
Marks dumb question - with a sub box how important is the shape of it compared to the size/volume? Want to make up a box to hug the left side of the boot & on top of the wheel arch rather than the big wanky cube I have now which doesn\'t fit nicely anywhere
Shape doesn\'t matter. as long as the size/volume is matched to the sub specs you\'ll be sweet
 ADIKT']
Depends if its ported or not wouldn\'t it ?
no
Strictly speaking, yes, the shape does matter, particularly when talking ported boxes.
You can get into all sorts of wank about laminar flow, dead spots and high pressure areas. Which I used to.
For a joe-bloggs-boring sorta box, just make sure you have at least the diameter of your port between the end of the port and the face opposite it, I guess.
anyone know a coolant flush / system cleaner , that actually works
just on the mrs 97 corolla . coolant is still green but rad cap has crusty orange s*** round it . wanna flush/ clean they system before i replace coolant
(on the shop shelf it settles out to copper at the bottom 1/3 and blue top )
actually works really well . have put it in 3 cars . well 2 cars and one diesel digger . it will work if the care is making latte in the coolant tank . primera was bought like 3 years ago and did that to it . got daily driven and has since been sold
follow the instructions tho .
  • Guest locked this topic
