20106276_1487551517970302_77968219411938
Model: 99 V5 STI (GC8) - 301.19KW ATW
Displacement: 2L
Mods: GT3582R twisted, Link G4+, Five0 1000cc Injectors, Kelfords, Custom Everything, - (26PSi)
Fuel: BP 98
Tuner/Dyno: Glen Suckling (GDS Automotive) - (Hubs)
*** Also had a leaking exhaust manifold pre-turbo during this dyno session***
Edited by marcas1234
  • Like 8
  • 2 months later...
Model: 00 V6 STI (GC8) - 390KW 30 PSI, (253 kw is at 13 psi).
Displacement: 2L
Mods: GTX3071R twisted gen 1, Link G4+ wire in, black ops1400cc Injectors, 30 PSI, lots modified,  (1000HP capable block, Doweled, cdb, oil gallery mods, ARP headstud conversion).
Fuel: E75 ( read from dash EtOH sensor)
Tuner/Dyno: D TECH.
 In case anyone wonders, yes I could bolt a bigger turbo and go for stupid power above 500wkw easy enough car is built to take it, but why bother, this way car is responsive and fun to drive, I don't want a small rev range of useable power.
Edited by Username
  • Like 8
  • Subscribed Member
Model: 89 RS Legacy
Displacement: 2l
Mods: TD05, Yellow Injectors, V3 STI RA heads, Forged short block.
Fuel: BP 98
Tuner/dyno: APET
Potentially damaged exhaust valve, and heatsoaking like a mofo due to a crap intercooler.
Will fix it up and try again...
Displacement: 2L
Tuner/Dyno: D TECH.
3
That's absolutely f*cking mental.
1 hour ago, 94 Leone said:
but for how long....
Sent from my Baked potato using Telekinesis
Judging by a certain employee at dtechs Subaru probably F***ing ages.
Time will tell but on their recommendation  I made some changes. I am not prepared to risk anything, so bigger lift pump went on and other minor things were done.
Edited by Username
Model: 99 V5 Type R - 312kw @ 22psi
Displacement: 2.35L
Mods: EJ22T, GT3076R gen 1, Syvecs S6 GP, 850cc Injectors, 22 PSI, AVCS Heads, L19 studs, Mahle 2618 Pistons, Pauter Rods, 79mm Crank + more
Fuel: BP 98
Tuner/Dyno: Raijin Performance
HI Admin,
could we perhaps add another category to the mods list and break it down further - seeing as there are so many ECU's out there these days like Link and Autronic and so many others. Also unsure if we can add a category for turbo and boost level so others get some guidelines/inspiration on what all is going on....
Model:
Displacement:
Mods:
Turbo/Boost:
Fuel:
ECU:
Tuner/dyno:
Edited by Pappu1
update for Furzes
Model:  1996 Subaru WRX STi
Displacement: 2L
Mods: Custom exhaust, 4 Bar map sensor, Turbosmart 44mm wastegate, Flipped V8 STi Spec C manifold, FMIC, 1000cc Bosch injectors, Aeromotive FPR, Aeroflow Fuel rails, complete teflon braided fuel lines, stock Version 7 STi Longblock w/ Supertech Dual Springs
Turbo/Boost: Steve Murch Motorsport Holset HRC35/2 22lb (ish, and for both 98 and e85)
Fuel: Flex Fuel BP 98 (275kw), e85 w/ 3.5bar base pressure (302.08kw)
ECU: Link G4+ Plug in
Tuner/dyno: @gotasuby aka @SAS
  • Like 5
  • 2 months later...
Gotasuby - 393.4wkw
Model: 2002 V7 STI GDB
Displacement: 2.35l
Mods: S300 Turbo, ID1700@50psi base. ported heads, cams, fmic, 3" exhaust, DW300 FP, G4+, Twin scroll legacy headers.
Fuel: E85
Tuner: Me/SAS
Update to this car. We built a new engine for this year rally sprints. Wanted to max out turbo and header setup. Think the small legacy headers are at there limit. All at 25psi
98 tune shown as well
Upgrade to efr turbo and better headers should see 450wkw
  • Like 5
Gotasuby - 393.4wkw
Displacement: 2.35l
Fuel: E85
Tuner: Me/SAS
Curious, what's done to the cams / heads
Sent from my TA-1012 using Tapatalk
Other than the porting of course.
Because I was interested in seeing what they actually make so I found out...
186.4wkw at 5900rpm B| not the least powerful car
375.5Nm at 3300rpm
Model: 2008 GRB STI (JDM)
Displacement: 2L
Mods: Titanium exhaust system done in Japan. :kidney:
Turbo/Boost: Stock /Stock
Fuel: 98
ECU: Stock
Tuner/dyno: Subaru / PBMS
Edited by Gripless
Kelford b cams, and cnc porting plus all extras by Kelford. Oversize valves and springs etc.
Model: V7 Sti
Displacement: 2.0
Mods: Fuel pump, K&N panel air filter, 3 port, 3 inch DP, 2.75inch catback
Turbo/Boost: Vf30 22.6psi
Fuel: BP98
ECU: Stock
Tuner/dyno: Chris from Prestige
Tuned at 32 degrees.
190kw 6400rpm
365nm 4400rpm
How important was the headwork, considering you probably started off with STi heads?
Reason I ask is that I too am going to run kelford B's, but on an EJ25 twin scroll with either a BW 300sx or holset hx35/2. (or whatever Murch says, to be fair) Looking for E85 at some stage, hence the question. Wondering if heads would only really start making a difference for E85?
@Berg the ej25 heads are way smaller than the ej20 ones so you'll have more restriction to start.
Insert Big D vs little o :$ joke here.
Read this Tomei page for all the areas they looked at developing parts.
http://www.tomeiusa.com/news/Report-EJ25-V1.html
MRT reckons 260wkw on the ej25 is the max without head work.
but even before that the more efficient you make the flow the less timing and stress you put into the engine to make whatever power you are after.
But porting has minimizing returns, the first about $500 gets you 85% of the gains of a $2000 job.
Ok so I was looking in to this a few weeks ago and talking to a couple of shops.
@gotasuby does this all sound right from your experience. My build won't start until later this year.
Edited by Gripless
What about the guy in the states running the crazy quarters with the unopened ej25 with stock heads?
*with cams and valves.
    574.7k
