Post up the following:
Example:
Model: V6 STI
Displacement: 2l
Mods: 272 cams, GT3582, ID1000's
Fuel: E85
Tuner/dyno: PBMS
Full graph showing correction, torque and power.
Standard rules apply as per previous years. Must own the car still and be in same guise as power run.
Copypasta as follows:
Model:
Displacement:
Mods:
Fuel:
Tuner/dyno:
#1
Gotasuby - 393.4wkw
Model: 2002 V7 STI GDB
Displacement: 2.35l
Mods: S300 Turbo, ID1700@50psi base. ported heads, cams, fmic, 3" exhaust, DW300 FP, G4+, Twin scroll legacy headers.
Fuel: E85
Tuner: Me/SAS
https://i.imgur.com/XMcznmY.jpg
Update to this car. We built a new engine for this year rally sprints. Wanted to max out turbo and header setup. Think the small legacy headers are at there limit. All at 25psi
#2
Username - 390wkw
Model: 00 V6 STI (GC8) - 390KW 30 PSI, (253 kw is at 13 psi).
Displacement: 2L
Mods: GTX3071R twisted gen 1, Link G4+ wire in, black ops1400cc Injectors, 30 PSI, lots modified,  (1000HP capable block, Doweled, cdb, oil gallery mods, ARP headstud conversion).
Fuel: E75 ( read from dash EtOH sensor)
Tuner/Dyno: D TECH
#3
shadywrx - 323.5wkw 535.8Nm e85/just under 280wkw on 98
Model: V7 STI
Displacement: 2l
Mods: Tomei Arms M8625 turbo etc etc etc
#4
YoungOne
Model: 99 V5 Type R - 312kw @ 22psi
Displacement: 2.35L
Mods: EJ22T, Syvecs S6 GP, 850cc Injectors, AVCS Heads, L19 studs, Mahle 2618 Pistons, Pauter Rods, 79mm Crank + more
Turbo/Boost: GT3076R gen 1 and 22 PSI
Fuel: BP 98
ECU: Syvecs S6 GP
Tuner/Dyno: Raijin Performance
#5
Furze - 302.08wkw
Model:  1996 Subaru WRX STi
Displacement: 2L
Mods: Custom exhaust, 4 Bar map sensor, Turbosmart 44mm wastegate, Flipped V8 STi Spec C manifold, FMIC, 1000cc Bosch injectors, Aeromotive FPR, Aeroflow Fuel rails, complete teflon braided fuel lines, stock Version 7 STi Longblock w/ Supertech Dual Springs
Turbo/Boost: Steve Murch Motorsport Holset HRC35/2
Fuel: Flex Fuel BP 98 (275kw), e85 w/ 3.5bar base pressure (302.08kw)
ECU: Link G4+ Plug in
Tuner/dyno: @gotasuby aka @SAS
#6
Marcas1234 - 301.19wkw
Model: 99 V5 STI (GC8) - 301.19KW ATW
Displacement: 2L
Mods: GT3582R twisted, Link G4+, Five0 1000cc Injectors, Kelfords, Custom Everything, - (26PSi)
Fuel: BP 98
Tuner/Dyno: Glen Suckling (GDS Automotive) - (Hubs)
#7
Boon – 268wkw
Model: V7 STI
Displacement: 2L
Mods: Holset WH1C twisted, Link G4, 1600cc Injectors, Process West TMIC, Llama Engineering custom all sorts of stuff
Fuel: BP 98 Octane
Tuner/dyno: Chris Wall, STM Dynapack
#8
Niran - 254wkw
Model: 2011 WRX STI Sedan
Displacement: 2500cc
Mods: Forged rebuild, Invidia TBE, DW65c, ID1000s, AEM CAI, AEM water/meth injection, Perrin FPR, Turbosmart IWG75 (17psi spring) and GFB Mach 2
Turbo/Boost: Stock / 22psi
Fuel: Gull force 10
ECU: Stock
Tuner/dyno: Possum Bourne / rolling road
Power: 254kw and ~520nm
#9
Hurrie/Niran - 244.46wkw
Model: 2011 Subaru STi Sedan
Displacement: 2.5L
Mods: 3" Catless downpipe with stock catback, DW65c fuel pump, Injector Dynamics 1000cc injectors, Perrin Fuel Pressure regulator, Grimmspeed 3port boost solenoid, AEM cold air intake and AEM Methanol injection running 50% water/meth mixture. Engine rebuilt using Mahle 4032 pistons, Eagle rods, ACL bearings/Headstud kit etc. Stock turbo & intercooler.
Fuel: 98
Tuner/dyno: Built and dyno'd by SAS, tuned by GK EuroTuning
#10
Batbaruman - 241.4wkw
Model: WRX STI V7 - GDB
Displacement: 2.0L
Mods: Decapped STI Pink injectors, 3" TBE, 4" intake with poddy, bigger (unknown brand) top mount, Manifold spacers, oil cooler, larger throttle body, Murch TD05 in twisted turbo setup, bosch 044 pump, Tial wastegate, Tomei fuel reg, unknown BOV, Link ECU
Fuel: BP98
Tuner/dyno:  PBMS/ Rollling road (Dyno Torque is the dyno brand?)
#11
McMasterJamie - 223.3wkw
Model: Subaru Legacy 2002 STI V7 engine
Displacement: 2L
Mods: VF34 Turbo, silicone intake, 3inch from turbo back, SSI headers, Process West TMIC, 3 port mac solenoid, kinugawa wastegate actuator, dw65c fuel pump
Fuel: 98 BP
Tuner/dyno: Chris - Prestige Tuning and Motorsport / Dynapack
#11
94 Leone - 220.7wkw
Model:  04 V9 STi -220.7kW ATW
Displacement: 2L
Mods: Full silicone intake w/ CAB & Blitz LM filter, 3mm thermal mani spacers, 3" RAGE exhaust, DW300 fuel pump, Link 3 port BCS.
Fuel: BP 98
Tuner/dyno: Chris@ Prestige Tuning, Dynapack
#12
Niran – 220wkw
Model: V8 STI
Displacement: 2L
Mods: Custom 3 inch exahust, Walbro feul pump, 3 port solenoid
Fuel: Gull Force 10
Tuner/dyno: Chris - Dtech (at the time)
#13
A_J_T - 213.6wkw
Model: 2001 BE5D Legacy B4
Mods: ST Conversion, VF34P20, 3" TB Exhaust, FMIC
Fuel: BP 98
Tuner/dyno: Dtech/Dave, Dynapack
#14
Johnnynz - 201.6wkw
Model: 1998 WRX
Displacement: 2l
Mods: VF22, V8 STI TMIC, TBE, Link G4
Fuel: BP 98
Tuner/dyno: Keith Stewart, Dyno pro
#15
Pedro - 201wkw
Model..  V4 sti Type R coupe
Displacement..2 litre
Mods..vf22 20psi, flipped and twisted, front mount, link G4,yellows
Fuel..BP98
Tuner..Keith Stewart Dynapack..
#16
Runrabbit - 197wkw
Model: V4 GC8
Displacement: 2l
Mods: Link G4, Process West TMIC, 3" TB Exhaust. Walbro, VF22
Fuel: BP 98
Tuner/Dyno: Mark/Dtech, Dynapack
#17
Kiwiflyboy - 193.3wkw
Model: SF5 Forester ST/b
Displacement: 2L
Mods: Link G4, VF30, 550cc Injectors, 3 inch from after downpipe
Fuel: 98
Tuner/dyno: NZEFI
#18-tied
Dairusire - 192.2wkw
Model: 1999 WRX STi Type RA Version 5
Displacement: 2.0L
Mods: VF36 Twin scroll conversion,17PSI boost, rage downpipe and ZeroSports exhaust, Link G4+ Storm, DW300 Fuel pump, Bosch Motorsports 1000cc injectors, aeromotive FPR
Fuel: 98 Ron
Tuner/dyno: Dave @ D-Tech, hub Dyno
#18-tied
Andy_Mac - 192.2wkw
Model: 2006 GT Spec B
Displacement: 2l
Mods: VF45, FMIC, Decatted DP, Aftermarket Catback
Fuel: BP 98
Tuner/Dyno: Dtech
#19
Thunda - 187wkw
Model:  92 RS EJ20G - 187kW ATW
Displacement: 2L
Mods: TD05 16g?, Yellows, FMIC, EWG, HKS Downpipe to Zerosports exhaust, Big Fuel pump, V3 Wasted spark setup, Link G4+
Fuel: BP 98
Tuner/dyno: PBMS
#20
Mitch8198 - 179.5awkw @ 15psi
Model: V3 WRX
Displacement: 2L
Mods: VF30, Link G4+, V7 STi top mount, V1 RA cdb, 440's, fpr, Link bcs, Link iat, full catless exhaust & headers.
Fuel: BP 98
Tuner/dyno: Keith Stewart / Dynapack
#21
Timmah - 171.3wkw
Model: 2002 Wrx Wagon GGA
Displacement: 2l
Mods: TD05 Turbo, Decatted factory DP, Silicon intake, V7 STI Intercooler, DW200
Fuel: BP 98
Tuner/Dyno: SAS
  • Like 5
Model: 1998 WRX
Displacement: 2l
Fuel: BP 98
Tuner/dyno: Keith Stewart, Dyno pro.
Comparison is same mods with STI ECU pinging its arse off.
4a56aa9e-d44d-4dfa-b33c-794215ac0404_zps
Displacement: 2L 9:1 comp
Mods: ST Conversion, VF34-P20, 3in TBE, FMIC
Fuel: BP 98
Tuner/dyno: Dave - DTech,  Dynapacks
Can't find the Dyno sheet atm but will find.
Youtube video is below
Displacement: 2.0L
Mods: VF23,Greddy / Trust Profec B EBC @ 20lb-ish, Syms Headers, 3" exhaust
Fuel: 98 Ron
Tuner/dyno: (didn't tune, was power run) Torque Performance, rolling road.
Power figure came out at 183Kw on a nice hot summers day with max heat soak.
Original tune...
Model: GC8D
Displacement: 2.0l
Mods: Vf30, chinese semi tuned headers, link G4, 3" exhaust, fuel pump, fpr, split fuel lines
Fuel: Mobil 98
Tuner/dyno: E&H
Made 201kw at the wheels. Main limiting factor was the stock top mount. Have gone front mount, and booked for a retune next thursday, gunning for that 223kw (300 hp at the wheels)
37 minutes ago, Passtheacid said:
Original tune...
Model: GC8D
Displacement: 2.0l
Fuel: Mobil 98
Tuner/dyno: E&H
Should be interesting to see Your car vs mine for power output. Main differences will be that I'm running e85 with upped compression and T/S VF36 setup.
Model: V7 STI
Displacement: 2L
Fuel: BP 98 Octane
I suck and can't find my dyno plot. 268kw.
Model: V4 GC8
Displacement: 2L
Mods: Link G4, Process West TMIC, 3" TBE, Walbro fuel pump, VF22
Fuel: BP 98 Octane
Tuner/dyno: Mark, DTech Dynapack
197kw
Edited by runrabbit
update attachment
Model: V7 STI
Displacement: 2L
Mods: Deatschwerks fuel pump, K&N typoon intake, turbo back exhaust
Fuel: Mobile 98
Tuner/Dyno: Amit (Road Tune) / PBMS
217kw
  • Joker pinned this topic
Am I allowed to put my motor that is in another car? It's our rally car engine that since we have crashed have lent the engine to a mate to go to the drags with while we build our new car.
If it 'made' the power in the car, then I see no reason not to considering it's still running. Gutted that the car got munted.
Point of this is people get a chance to share results and get on the leaderboard. If we dont keep it fresh we would have the same 10 odd cars on it which is lame.
Welcome to post results this threads all about seeing whats achievable from where Im sitting not just a claim to top 10 fame.
Ill let it slide its pretty grey but due to circumstances allgood.
Model: 2002 Impreza WRX Wagon, GGA
Displacement: 2L
Mods: TD05 Turbo, Decatted factory downpipe, Silicone intake, Version 7 STi intercooler, Deatchwerkz DW200
Fuel: BP 98
Tuner/dyno: SAS
QFPyo0z.png?1
Model: 2002 v7 Impreza sti, GDB
Displacement: 2L
Mods: s300 Turbo, ID1000 @58psi base, ported heads, cams, fmic, 3" exhaust, Deatchwerkz DW300, link g4+, twin scroll
Fuel: avgas/E18
Tuner/dyno: me/SAS
Displacement: 2L
Fuel: avgas/E18
Tuner/dyno: me/SAS
Have you got a sheet with tcf and ratio? Just to be fair.
Dunno why is my torque number so different to everyone elses, is it just because rolling road vs hub dyno? Anyway, bit late but here I am
Displacement: 2.0L
Fuel: BP98
Thats just how all the Dyno Torque torque figures seem to come out. Never quite worked out what kind of relationship it has to typical torque figures, most other rolling road ones will still give comparable figures to hub ones
  • 4 weeks later...
    574.7k
