1 hour ago, Loren said:
What is the purpose of the fender shroud? Never heard of anything like it before.
The factory ones on VA’s look super trash. It's like the black material under the hood.
Though at least they have something there, the GR/GV’s have a big gap that i’ve dropped a few bolts down into on mine
I looked it up on youtube... stupid that they leave giant holes there.
When you take the rubber out of the side fender grills the hot air gets sucked out of the top of the engine bay through those gaps.
You mean the fake openings just behind the wheels?
Most of these aftermarket ones are somewhat vented anyway so could still allow some airflow with the lower vents opened up
They aren’t fake.
they have rubber flaps behind the mesh to block them.
you rip it out and they work.
you can cut more hole in fender to drag more air through.
11 hours ago, Gripless said:
They aren’t fake.
True. I've never bothered actually looking at them before but know the US folks seem to cut up their guard liners to have direct flow to supposedly keep pressure low around the wheels rather than the engine bay
On 1/07/2021 at 11:40 PM, Gripless said:
They aren’t fake.
Seems Ive got some rubber things to remove ?
  • Haha 1
If you are careful you can just pull the top of the vent panel. Top of the Sti logo outwards and get 30mm or so gap. They just grab the rubber and pull away from vent.
Only one side of the rubber is held on by tiny 4mm washers on plastic pins.
if you get brave unscrew the side skirt from front arch and the the bottom of the panel has a small clip at the bottom.
you can then cut or drill some more holes to get better flow.
There is 40mm before you hit the actual car frame.
Edited by Gripless
Installed a CTEK battery sense bluetooth module and MXS 5.0 charger. The module is a nice little item for those of us with only occasionally used vehicles that aren't properly garaged to allow for long term use of the battery maintainer setup but still at close range for it to ping a phone occasionally.
Straight off the bat it was sitting at 30% as expected from the difficulty starting the last few times so hopefully the chargers recond feature should be able to bring this most of the way back.
Bit of an engine detail the other day
[img]https://i.ibb.co/g72ppfG/20210807-183013.jpg[/img]
[img]https://i.ibb.co/DRdBdmJ/20210807-183027.jpg[/img]
[img]https://i.ibb.co/c1qKS1m/20210807-183036.jpg[/img]
[img]https://i.ibb.co/x89PxhH/20210807-183059.jpg[/img]
[img]https://i.ibb.co/19j2mzx/20210807-183113.jpg[/img]
[img]https://i.ibb.co/gFfbLDj/20210807-183122.jpg[/img]
Edited by TNHSTI
Has they way we post images on the forum changed recently ? They keep just showing up like above for me ..
  • Subscribed Member
You don't need the img tags anymore, just paste the link to the image, make sure it's plain text, it may prompt you to switch to that,  and hit enter after and it should automatically make it an image :)
Should produce:
13 hours ago, Conducks said:
Installed a dinky little rear brake light/reverse light on my STi yesterday, it’s the little things emoji846.png
Nice. My red start stop buttons like yours turned up yesterday so I'll have a go with them tonight.
Aliexpress deals are on!
1 hour ago, ADIKT said:
These were delivered yesterday - will start putting things together after work tomorrow
What you got? Rear subframe lock kit... and?
Front and rear essential kits. Will mean I can get the damn thing rolling on its own wheels. Finally.
    574.3k
