fitted new fmic and uped the piping to 3inch with a new 50mm bov.. got out the angle grinder and shaved the bumper back sum more to get the cooler to fit behind it with out having a whooping great hole in th middle o the bumper (im a big fan of the factory stealth look) which was a mission on its own as the coolers 600x300x110..
 al']
[quote name='smokn4 said:
threw a carbon fibre strut brace in today ;D
after selling off my old alloy strut bar and getn this sti one i realised how light they are when you compare them....
carbon fibre one was half the weight of my old alloy one :D
WRXONP - evidence, as per previous discussion..?
can only get evidence if al is willing to take my old strut brace of his car and weight it as its no longer in my possesion......
but i cant tell you that the carbon fibre one was about half the weight of my old alloy one
as for you WRXONP....you must be on crack if you think that FHI's aerospace division cant make a lighter and better strut bar than them cheap chineese ones out there......SNAP! :D :D :D :D :D
Yes I can do that at some stage, thu or fri if I remember. I have smokn4's old alloy brace and my carbonfibre brace. Need to remove cf brace from sti and weigh it. 15 min job, but getting a round to it may take longer :)
STI carbon fibre: 1.500kg
Other nice pink and alloy: 2.245kg
Weight difference: 0.995kg on a 1300kg car = SFA
 aim said:
having CF in your car is like having a prince albert. Pimp, but only when you pop the hood.
Still looks the part under an alloy bonnet :D
Not today, but have just sorted out getting pictures :-\ ... couple of weekends ago put in some Tein springs and a Kakimoto axle-back muff. Got the parts cheap, put em in myself, stoked with the result!
185711_10150094388595885_582420884_63545
183535_10150094388680885_582420884_63545
Lower
183577_10150094388700885_582420884_63545
182716_10150094388830885_582420884_63545
Louder ;D
 DRFVDR said:
Gave my Landcruiser a 10,000 k service that is number 40 @ 410,000 K/m,also came to the realisation that I have owned it for 20 years :)
Damn, that's a nice long time! :o
Lower
Louder ;D
Looks toight!
 gmeago']
img]http://i1190.photobucket.com/albums/z453/JoshHussey1/185711_10150094388595885_582420884_6354505_4823840_n.jpg[/img]
Lower
Louder ;D
Looks toight!
nice car nice rime nice deal mate Nice!!!!
turned the key for the 1st time tonight after the shortblock replacement............ had to jump the battery as turning it over without the fuel on to get some oil pressure 1st before i tried to start killed it!!
right the mrs car hooked up via jumper cables...............
**hangs head in shame because the mrs "mitsi" cedia turbo is running**
no go sonny!!! dam..... where to next??????
 funkytown said:
what size huffer are you running in that mix rskikn?
garrett gt3082r.. little bit lagy but does the job once its got boost.. can always fick the anti lag lol.. the bigger pipes on the hot side actually helped get rid of sum and brings the turbo in harder.. gonna do the cold side tomorrow and wire in the in-tank 044 then shoud be ready for the dyno again.. 4th times the charm!
 rskikn']
[quote name='funkytown said:
what size huffer are you running in that mix b]rskikn?[/b]
oh nice - have any plots and power curves i can have a look at? What box is it all mated too? running a gt3071 on mine see :)
 funkytown']
gt3071r?? or 76? its got a 98 sti gear box and rear diff (4:44) and sum red line shock proof gear oil.. seams to be holding up ok so far was gonna go 6 speed but to much work u basicly gotta put all the running gear under it be cheaper just to get a v7 lol.. yea ill take sum pics of the dyno sheets one of thems got my old plate on it tho slitha.. tune wasnt finished when kent pulled it off the dyno tho cos the pump maxed out..
oh true true! yer i only have a 3071r, is putting out 278 atw currently and pulls like a porno star.. will do more it has some more boost wound into it. Definitely helps having the 6speed behind it though.
/cut the rest of what i was saying. its OT. I will pm you for some chit chat.
