 T.Rev said:
Got woffed..need new front right...badly worn on inside due to camber. Also noted I need 4 swaybar link rods..2 figure eight? types and 2 C shapes
Are swaybar link rods just swaybar links? If so I have four standard C shape (rear) links spare. Where are you located?
Removed front brembo brake calipers today due to a loud scary noises after being rebuilt, remove brake pads and checked pistons for movement, some pistons are seized , now i know why its was so freckn loud and chewing up my endless brake pads and dds rotors, not happy chappy :-[
Just gave it a wash... only the outside though as I will probably take the dogs out later. Need to take it for a spin as I replaced the rocker cover gaskets last night and need to burn off the little bit of oil that dripped onto the exhaust manifold.
 Fastfour said:
Reinstalled rebuilt gearbox into the racecar only to find that it won\'t go into reverse. bother!!
I\'ve got one of those boxes in the shed too jase, what happens when you build two boxes at the same time & put the wrong idler cog in the wrong box, ;D
 rex-leggy']
[quote name='Fastfour said:
Getting it out of the garage is an issue. You don\'t realise how much you use reverse till is not an option
Have ya checked if the shifter linkage for reverse is allgood? Could be pretty simple fix
Yep have checked that. It\'s gonna be a box pull apart job. Bring on Wings and Wheels in March and then Taupo Winter Series!!
Put it up on stands to change the clutch... couldn\'t close the garage door because the car was back too far!
Decided to take the bumper off to make room... plus I need to fix a leak under it... removing the bumper
required removing the tow bar, which in turn required removing the exhaust. So in all, took over an hour.
At least I discovered the rear bumper has clearly never been off, hence never been in a rear end crash :)
 JoKer said:
haha \'just\' to do a clutch
is this going to be one of those half hour jobs that turns into a 6 year build???
haha, clutch change in half an hour ;)
No, just changing the clutch... and if I have time, do some grinding on the rear struts for some camber...
and maybe start stripping out the sound deadening... will resist taking rear diff out and re shimming...
I\'m committed to doing the Alexandra Rd hillclimb in March, so no bothering around.
in the past week i have flipd my manifold, removed my ABS unit and lines, replaced brakes, gotten engien ready to make a coustom manifold to fit a T04e T3/4 turbo, Painted rocker covers and manifold + wastegate and BOV matt black, ripped out all the gay blue hoses and more haah
